The pins are much thinner than the headers of the expansion board
mendrugory
Post by mendrugory » Sat Oct 17, 2015 5:25 pm
I have received my wipy with the expansion board and a couple of pin connector this week. My first try has been to use the wipy with the expansion board, because it does not have pins, but the pins are much thinner than the headers so they are not able to connect.
Am I doing anything wrong?
http://www.jpegmini.com/widget/144b44b9 ... 3583113d19
http://www.jpegmini.com/widget/c012f8a2 ... 39700c772a
Best regards,
Gonzalo.
Re: The pins are much thinner than the headers of the expansion board
Post by dhylands » Sat Oct 17, 2015 6:26 pm
It looks like you got female headers instead of male headers (I seem to recall seeing options for both on some of the rewards). What you want is something that looks like:
https://www.sparkfun.com/products/116
or there are what's know as stackable headers which looks sort of like what you have, but with much longer leads:
https://www.sparkfun.com/products/11417
danicampora
Post by danicampora » Sat Oct 17, 2015 7:27 pm
You were one of the backers that ordered female headers + the expansion board. Since female headers are not compatible (not directly) with the expansion board, we decided to make you guys a favor a send the headers loose instead of soldering them so that you can decide what to do.
Cheers,
Daniel
mendrugory
Post by mendrugory » Sat Oct 17, 2015 7:42 pm
Thank you for your answers.
mendrugory
Post by mendrugory » Sat Oct 17, 2015 10:37 pm
Although I can not take advantage of your favor, thanks again, it is very easy to use the expansion board.
http://www.jpegmini.com/widget/ec6cde72 ... d3f6fd5ae5
By the way, very good product.
Best regards,
Gonzalo.
