Plotting the output of os.urandom(512) to a bitmap display is disturbingly non-random:
os.urandom... isn't very random?
Re: os.urandom... isn't very random?
What did you plot (i.e. what is the X axis and what is the Y axis)?
I made two tests. For PyBoard, I collected sufficient data to run the NIST800-22 test. It passed all tests.
For WiPy, I just collected 16k Bytes and just looked at the histogram, the simple plot (value vs. index) , a scatterplot( first half vs. second half) and a spectrogram. None of that looks obviously wrong. For the NIST test, I need about 120 MByte of data. To get these from Wipy requires a little bit more of programming than 5 lines of code. So it'll take a while.
- danicampora
The pyboard has a true harward random number generator, while the WiPy on the other hand as a software pseudo random one. The WiPy one is good enough in most cases, but I doubt it'll pass the NIST tests...
Cheers,
Daniel
Cheers,
Daniel
A good pseudo-random number generator with a sufficiently long period should pass the NIST test, because this test looks for randomness, not for predictability. And if you are using an algorithm like AES or DEA in feedback mode for the generator, that should work. Looking at the code I see that WiPy uses a 24 bit LFSR. I extracted that into a little C program. generated data and did the NIST test on it. It did not fail every test. Bruce Schneier has published two other examples, which perform better, if that is of any matter.
https://www.schneier.com/cryptography/a ... equen.html
It's really not ok for os.urandom to use an LSFR generator. It's supposed to be cryptographically secure. If there is a way to initialize it through user input timings or something, then running a cryptographic PRNG is hopefully ok. But it would be good if there was some NVRAM or something to maintain the PRNG state between powerups.
Collected about 4MB of os.urandom(1024) concatenated and ran this test (where ocassional low or high p values will occasionally occur in a good trng, that is, in another collection that one weak will go away and maybe another will appear elsewhere, it happens):
chuck@pe1950b:~$ dieharder -a -f bigrand
# dieharder version 3.31.1 Copyright 2003 Robert G. Brown #
rng_name | filename |rands/second|
mt19937| bigrand| 1.25e+08 |
test_name |ntup| tsamples |psamples| p-value |Assessment
diehard_birthdays| 0| 100| 100|0.61695785| PASSED
diehard_operm5| 0| 1000000| 100|0.03918532| PASSED
diehard_rank_32x32| 0| 40000| 100|0.00254075| WEAK
diehard_rank_6x8| 0| 100000| 100|0.32426917| PASSED
diehard_bitstream| 0| 2097152| 100|0.90983775| PASSED
diehard_opso| 0| 2097152| 100|0.31136592| PASSED
diehard_oqso| 0| 2097152| 100|0.88849299| PASSED
diehard_dna| 0| 2097152| 100|0.02632160| PASSED
diehard_count_1s_str| 0| 256000| 100|0.53418033| PASSED
diehard_count_1s_byt| 0| 256000| 100|0.10833179| PASSED
diehard_parking_lot| 0| 12000| 100|0.40756286| PASSED
diehard_2dsphere| 2| 8000| 100|0.62485804| PASSED
diehard_3dsphere| 3| 4000| 100|0.96434579| PASSED
diehard_squeeze| 0| 100000| 100|0.92749868| PASSED
diehard_sums| 0| 100| 100|0.31733302| PASSED
diehard_runs| 0| 100000| 100|0.76171815| PASSED
diehard_runs| 0| 100000| 100|0.53259081| PASSED
diehard_craps| 0| 200000| 100|0.06443498| PASSED
diehard_craps| 0| 200000| 100|0.95361196| PASSED
marsaglia_tsang_gcd| 0| 10000000| 100|0.07229466| PASSED
marsaglia_tsang_gcd| 0| 10000000| 100|0.80494213| PASSED
sts_monobit| 1| 100000| 100|0.01221109| PASSED
sts_runs| 2| 100000| 100|0.19410883| PASSED
sts_serial| 1| 100000| 100|0.43740452| PASSED
sts_serial| 2| 100000| 100|0.76149357| PASSED
sts_serial| 3| 100000| 100|0.43520694| PASSED
sts_serial| 3| 100000| 100|0.76020044| PASSED
sts_serial| 4| 100000| 100|0.76252435| PASSED
sts_serial| 4| 100000| 100|0.97424261| PASSED
sts_serial| 5| 100000| 100|0.24626500| PASSED
sts_serial| 5| 100000| 100|0.81633438| PASSED
sts_serial| 6| 100000| 100|0.26457489| PASSED
sts_serial| 6| 100000| 100|0.69164995| PASSED
sts_serial| 7| 100000| 100|0.46649650| PASSED
sts_serial| 7| 100000| 100|0.92070611| PASSED
sts_serial| 8| 100000| 100|0.56905248| PASSED
sts_serial| 8| 100000| 100|0.90358265| PASSED
sts_serial| 9| 100000| 100|0.93444552| PASSED
sts_serial| 9| 100000| 100|0.99458113| PASSED
sts_serial| 10| 100000| 100|0.86543565| PASSED
sts_serial| 10| 100000| 100|0.40262869| PASSED
sts_serial| 11| 100000| 100|0.88516655| PASSED
sts_serial| 11| 100000| 100|0.94037598| PASSED
sts_serial| 12| 100000| 100|0.75323099| PASSED
sts_serial| 12| 100000| 100|0.85525976| PASSED
sts_serial| 13| 100000| 100|0.87538565| PASSED
sts_serial| 13| 100000| 100|0.57705181| PASSED
sts_serial| 14| 100000| 100|0.44317210| PASSED
sts_serial| 14| 100000| 100|0.58562576| PASSED
sts_serial| 15| 100000| 100|0.18821489| PASSED
sts_serial| 15| 100000| 100|0.46040268| PASSED
sts_serial| 16| 100000| 100|0.83894356| PASSED
sts_serial| 16| 100000| 100|0.73328515| PASSED
rgb_bitdist| 1| 100000| 100|0.53312740| PASSED
rgb_bitdist| 2| 100000| 100|0.73311971| PASSED
rgb_bitdist| 3| 100000| 100|0.74776632| PASSED
rgb_bitdist| 4| 100000| 100|0.92487323| PASSED
rgb_bitdist| 5| 100000| 100|0.06238251| PASSED
rgb_bitdist| 6| 100000| 100|0.95538826| PASSED
rgb_bitdist| 7| 100000| 100|0.98758602| PASSED
rgb_bitdist| 8| 100000| 100|0.72461133| PASSED
rgb_bitdist| 9| 100000| 100|0.72909151| PASSED
rgb_bitdist| 10| 100000| 100|0.16866374| PASSED
rgb_bitdist| 11| 100000| 100|0.94563096| PASSED
rgb_bitdist| 12| 100000| 100|0.84388674| PASSED
rgb_minimum_distance| 2| 10000| 1000|0.05088220| PASSED
rgb_minimum_distance| 3| 10000| 1000|0.49882948| PASSED
rgb_minimum_distance| 4| 10000| 1000|0.84127071| PASSED
rgb_minimum_distance| 5| 10000| 1000|0.41340460| PASSED
rgb_permutations| 2| 100000| 100|0.24236399| PASSED
rgb_permutations| 3| 100000| 100|0.89899169| PASSED
rgb_permutations| 4| 100000| 100|0.62104572| PASSED
rgb_permutations| 5| 100000| 100|0.19781278| PASSED
rgb_lagged_sum| 0| 1000000| 100|0.49335812| PASSED
rgb_lagged_sum| 1| 1000000| 100|0.57442446| PASSED
rgb_lagged_sum| 2| 1000000| 100|0.72623778| PASSED
rgb_lagged_sum| 3| 1000000| 100|0.76799308| PASSED
rgb_lagged_sum| 4| 1000000| 100|0.02997482| PASSED
rgb_lagged_sum| 5| 1000000| 100|0.18870353| PASSED
rgb_lagged_sum| 6| 1000000| 100|0.43936165| PASSED
rgb_lagged_sum| 7| 1000000| 100|0.38212618| PASSED
rgb_lagged_sum| 8| 1000000| 100|0.21711583| PASSED
rgb_lagged_sum| 9| 1000000| 100|0.03174413| PASSED
rgb_lagged_sum| 10| 1000000| 100|0.78621228| PASSED
rgb_lagged_sum| 11| 1000000| 100|0.07425169| PASSED
rgb_lagged_sum| 12| 1000000| 100|0.65158704| PASSED
rgb_lagged_sum| 13| 1000000| 100|0.31547852| PASSED
rgb_lagged_sum| 14| 1000000| 100|0.86615011| PASSED
rgb_lagged_sum| 15| 1000000| 100|0.94580508| PASSED
rgb_lagged_sum| 16| 1000000| 100|0.90628965| PASSED
rgb_lagged_sum| 17| 1000000| 100|0.42661627| PASSED
rgb_lagged_sum| 18| 1000000| 100|0.92157677| PASSED
rgb_lagged_sum| 19| 1000000| 100|0.60133352| PASSED
rgb_lagged_sum| 20| 1000000| 100|0.52296843| PASSED
rgb_lagged_sum| 21| 1000000| 100|0.37980474| PASSED
rgb_lagged_sum| 22| 1000000| 100|0.98505308| PASSED
rgb_lagged_sum| 23| 1000000| 100|0.86384453| PASSED
rgb_lagged_sum| 24| 1000000| 100|0.91244148| PASSED
rgb_lagged_sum| 25| 1000000| 100|0.41447060| PASSED
rgb_lagged_sum| 26| 1000000| 100|0.68715712| PASSED
rgb_lagged_sum| 27| 1000000| 100|0.06450373| PASSED
rgb_lagged_sum| 28| 1000000| 100|0.76268183| PASSED
rgb_lagged_sum| 29| 1000000| 100|0.86828993| PASSED
rgb_lagged_sum| 30| 1000000| 100|0.65213018| PASSED
rgb_lagged_sum| 31| 1000000| 100|0.22795356| PASSED
rgb_lagged_sum| 32| 1000000| 100|0.04675176| PASSED
rgb_kstest_test| 0| 10000| 1000|0.02459689| PASSED
dab_bytedistrib| 0| 51200000| 1|0.51907397| PASSED
dab_dct| 256| 50000| 1|0.98987543| PASSED
Preparing to run test 207. ntuple = 0
dab_filltree| 32| 15000000| 1|0.52251896| PASSED
dab_filltree| 32| 15000000| 1|0.25957927| PASSED
Preparing to run test 208. ntuple = 0
dab_filltree2| 0| 5000000| 1|0.29477193| PASSED
dab_filltree2| 1| 5000000| 1|0.68797791| PASSED
Preparing to run test 209. ntuple = 0
dab_monobit2| 12| 65000000| 1|0.16430290| PASSED
