Controlling hobby servos
Re: Controlling hobby servos
But still, the servo is not moving at all, I don't understand why
And I think that I need a scope...
A scope has its place. I have both scopes and logic analyzers and I find that I use the logic analyzer alot more than I do the scope.
The logic analyzers typically will decode protocols like UART, I2C, and SPI for you, and can also be used for measuring PWM stuff.
I can definitely recommend the Logic series by https://www.saleae.com/ (no association). I have one of the original 8-channel Logic (not sold anymore) and one of the 16-channel Logic Pro's. For most things, 4 channels is adequate, and the new ones given you some number of analog channels as well.
I also really like that the UI software is cross platform.
I think that the Logic-4 is definitely worth it, and go for the Logic-8 if you can afford it (it supports higher speeds as well(. Although 4 channels seems to be enough for many things. The Logic-Pro-8 seems a bit steep for the typical hobbyist.
Thanks Dave for the info, I'm thinking about buying the Logic-4
Well, I own this one:https://www.lab-nation.com/
It combines a scope, logic analyser, and wave generator in a small form factor. And yes, even in scope mode it can recognise signals from I2C, SPI, RS232 etc.
I think it also depends where you are living, and what is locally available.
- danicampora
Hey guys,
Finally fixed the Timer class, and now PWM can be generated down to 5Hz. The duty cycle resolution has been improved as well, and it is 0.01% (must be specified as fixed point e.g. 50.55% => dutcy_cycle=5055) Timer IDs start from 0 like the rest of the peripherals and the PWM pin is assigned automatically when creating the Timer channel. Check the updated docs for more details.
Latest release: https://github.com/wipy/wipy/releases/tag/1.2.0
Cheers,
Daniel
Cheers,
Daniel
That's awesome Daniel, it works like a charm now, thanks!!
- danicampora
Hi mdgart,
I am glad to hear that, thanks for the feedback!
Cheers,
Daniel
Cheers,
Daniel
Hi Daniel,
after upgrading to https://github.com/wipy/wipy/releases/tag/1.2.0
everything works fine (including Timer with the new improvements) but I get :
>>> os.uname()
(sysname='WiPy', nodename='WiPy', release='1.1.1', version='v1.6-82-g12547ce-dirty on 2016-02-22', machine='WiPy with CC3200')
should not it be : release='1.2.0' ?
Thank you for taking time to improve Wipy despite the Lopy kickstarter !
Pascal
>>> os.uname()
Pascal
- danicampora
Hi PCA,
Uppsss... you are right. Fixed now and updated the release binaries. Thanks!
Cheers,
Daniel
Cheers,
Daniel
