PWM outputs simultaneously
Questions and discussion about The WiPy board.
Target audience: Users with a WiPy.
blueslow
Postby blueslow » Mon Dec 12, 2016 12:30 am
Hi
Can all 4 PWM outputs be used simultanesously and indenpendently on the wipy ( version 1)?
/Blueslow
blueslow
Re: PWM outputs simultaneously
Postby blueslow » Mon Dec 19, 2016 3:35 pm
After some research I have concluded the following.
The reason for my question in the first place was that I hade the impression that there were only two timer channels. That is not the case. Each of the four timer timers have two timer channels. With that information and the wipy pinout it is clear that at least three pwm outputs can be used independently and simultaneous.
Timer 2 and pwm3 is connected to the heart beat and is not so easy to use as it lacks an easy connection.
If your application allows time sharing of timer 3 between channel A and B then four pwm outputs can be used in the application.
A note about simultanous, because of set up time the PWM outputs are not exactly simultanous. I have not checked if the outpus are in phase with each other if they have the same frequency and duty cycle.
/Klas
Return to “The WiPy”
Who is online
Users browsing this forum: No registered users and 2 guests
