BLE char limited to 20 bytes on STM32 NUCLEO-WB55 ?
Yannick
Post by Yannick » Tue Jul 26, 2022 3:10 pm
Hello
This post is an update of the one I did almost a year ago (viewtopic.php?f=2&t=10465), with no solution found up to now.
I am facing exactly this issue, an trying to apply this solution :
Characteristics and descriptors have a default maximum size of 20 bytes. Anything written to them by a client will be truncated to this length. However, any local write will increase the maximum size, so if you want to allow larger writes from a client to a given characteristic, use gatts_write after registration. e.g. gatts_write(char_handle, bytes(100)).
(from https://docs.micropython.org/en/latest/ ... tooth.html, "GATT Server" section)
My BLE peripheral (not completely reproduced) code is looking like this :
# Maximum number of bytes that can be exchanged
_MAX_NB_BYTES = const(128)
class BLEperipheral:
	# Initializations
	def __init__(self, ble, name="mpy-uart", charbuf=_MAX_NB_BYTES):
		self._ble = ble
		self._ble.active(True)
		self._ble.irq(self._irq)
		# Registration of the service
		((self._tx_handle, self._rx_handle),) = self._ble.gatts_register_services((_UART_SERVICE,))
		# Extending chars buffers to 100 bytes
        	self._ble.gatts_write(self._tx_handle, bytes(charbuf))
		self._ble.gatts_write(self._rx_handle, bytes(charbuf))
		self._connections = set()
		self._rx_buffer = bytearray()
		self._handler = None
		# Advertising of the service (services=[_UART_UUID] is required for the exchange to identify the service)
		self._payload = advertising_payload(name=name, services=[_UART_UUID])
		self._advertise()
Despites I added the required instruction, when my Central script is writing inside RX characteristic using gattc_write it's message remains truncated to 20 bytes on Peripheral side !
It seems limitation is on gattc_write (Central client side) which is not able to write more than 20 bytes, not on the setup of the characteristic served by the Peripheral.
Maybe I am facing a limitation of BLE implementation on my NUCLEO WB55 board ?
If anybody has an idea ...
Best regards
Yannick
Re: BLE char limited to 20 bytes on STM32 NUCLEO-WB55 ?
Post by jimmo » Wed Aug 17, 2022 12:11 pm
You also need to do an MTU exchange. See https://docs.micropython.org/en/latest/ ... change_mtu
