i tried the patch on issue#448, and the compilation succeeded.
Testing directory mp-tests...
assert1 : 17 lines, 100.0% correct
assign1 : 38 lines, 100.0% correct
assign2 : 92 lines, 100.0% correct
augassign1 : 37 lines, 100.0% correct
call1 : 13 lines, 100.0% correct
class1 : 28 lines, 100.0% correct
class2 : 34 lines, 100.0% correct
class3 : 83 lines, 100.0% correct
class4 : 67 lines, 100.0% correct
class5 : 86 lines, 100.0% correct
class6 : 73 lines, 100.0% correct
class7 : 42 lines, 100.0% correct
closure1 : 7 lines, 100.0% correct
closure2 : 40 lines, 100.0% correct
closure3 : 56 lines, 100.0% correct
closure4 : 61 lines, 100.0% correct
compare1 : 75 lines, 98.7% correct
const1 : 17 lines, 94.1% correct
continue1 : 151 lines, 94.7% correct
decorate1 : 87 lines, 100.0% correct
del1 : 54 lines, 100.0% correct
del2 : 28 lines, 100.0% correct
dict1 : 22 lines, 100.0% correct
dictcomp1 : 53 lines, 100.0% correct
docstring1 : 49 lines, 100.0% correct
docstring2 : 9 lines, 100.0% correct
fun1 : 22 lines, 100.0% correct
fun2 : 134 lines, 100.0% correct
fun3 : 43 lines, 100.0% correct
fun4 : 30 lines, 100.0% correct
if1 : 70 lines, 100.0% correct
if2 : 60 lines, 100.0% correct
if3 : 33 lines, 93.9% correct, 1 bad 3-field
if4 : 40 lines, 97.5% correct
ifexpr1 : 13 lines, 100.0% correct
import1 : 32 lines, 100.0% correct
import2 : 13 lines, 100.0% correct
import3 : 47 lines, 100.0% correct
import4 : 22 lines, 100.0% correct
import5 : 33 lines, 100.0% correct
import6 : 91 lines, 100.0% correct
lambda1 : 31 lines, 100.0% correct
lambda2 : 18 lines, 100.0% correct
list1 : 41 lines, 100.0% correct
list2 : 39 lines, 100.0% correct
listcomp1 : 79 lines, 100.0% correct
listcomp2 : 29 lines, 100.0% correct
listcomp3 : 60 lines, 100.0% correct
listcomp4 : 44 lines, 100.0% correct
listcomp5 : 186 lines, 100.0% correct
locals1 : 91 lines, 100.0% correct
ptex : 1083 lines, 97.9% correct, 1 bad 3-field
raise1 : 70 lines, 98.6% correct
scope0 : 30 lines, 100.0% correct
scope1 : 43 lines, 100.0% correct
scope2 : 52 lines, 100.0% correct
scope3 : 58 lines, 100.0% correct
scope4 : 45 lines, 100.0% correct
scope5 : 56 lines, 100.0% correct
scope6 : 48 lines, 100.0% correct
scope7 : 78 lines, 100.0% correct
set1 : 29 lines, 100.0% correct
setcomp1 : 53 lines, 100.0% correct
slice1 : 95 lines, 100.0% correct
slice2 : 19 lines, 100.0% correct
string1 : 23 lines, 100.0% correct
string2 : 49 lines, 100.0% correct
super1 : 137 lines, 100.0% correct
try1 : 85 lines, 98.8% correct
try2 : 28 lines, 96.4% correct
try3 : 66 lines, 98.5% correct
try4 : 118 lines, 99.2% correct
try5 : 52 lines, 98.1% correct
try6 : 50 lines, 98.0% correct
tuple1 : 73 lines, 100.0% correct
tuple2 : 73 lines, 100.0% correct
tuple3 : 35 lines, 100.0% correct
with1 : 61 lines, 98.4% correct
yield1 : 69 lines, 100.0% correct
yield2 : 67 lines, 100.0% correct
Testing directory pylib-tests...
_compat_pickle : 252 lines, 99.6% correct
_threading_local : 445 lines, 99.1% correct, 1 bad 3-field
_weakrefset : 1115 lines, 99.3% correct
abc : 605 lines, 98.7% correct, 1 bad 3-field
aifc : 3295 lines, 98.7% correct, 5 bad 3-field
antigravity : 95 lines, 100.0% correct
base64 : 1407 lines, 99.4% correct
bdb : 2537 lines, 98.4% correct, 7 bad 3-field
binhex : 2012 lines, 99.4% correct, 5 bad 3-field
bisect : 270 lines, 98.1% correct
bz2 : 1552 lines, 99.3% correct, 2 bad 3-field
cProfile : 673 lines, 98.7% correct
chunk : 499 lines, 98.4% correct
code : 696 lines, 98.7% correct
compileall : mismatch in number of lines
contextlib : 736 lines, 97.6% correct, 11 bad 3-field
crypt : 220 lines, 98.2% correct
dummy_threading : 138 lines, 99.3% correct
fnmatch : 361 lines, 97.2% correct
genericpath : 319 lines, 98.4% correct
getopt : 766 lines, 98.4% correct
hashlib : 302 lines, 97.4% correct
heapq : 1146 lines, 99.0% correct
keyword : 232 lines, 97.4% correct, 1 bad 3-field
macurl2path : 390 lines, 98.5% correct
mimetypes : 1544 lines, 98.7% correct
modulefinder : 3033 lines, 98.1% correct
nturl2path : 267 lines, 97.8% correct
opcode : 724 lines, 100.0% correct
pipes : 905 lines, 99.3% correct
poplib : 1022 lines, 99.7% correct, 1 bad 3-field
pty : 666 lines, 98.2% correct
reprlib : 859 lines, 98.3% correct, 10 bad 3-field
rlcompleter : 438 lines, 96.6% correct
runpy : 958 lines, 99.0% correct
sched : 532 lines, 99.6% correct
shelve : 779 lines, 99.5% correct
socket : 1315 lines, 98.3% correct, 1 bad 3-field
socketserver : 1697 lines, 98.5% correct, 8 bad 3-field
sre_constants : 557 lines, 100.0% correct
stat : 367 lines, 99.5% correct
struct : 32 lines, 100.0% correct
sunau : 1718 lines, 99.2% correct, 3 bad 3-field
symbol : 249 lines, 99.2% correct
tabnanny : 1177 lines, 97.9% correct, 3 bad 3-field
tempfile : 2260 lines, 98.5% correct
this : 76 lines, 100.0% correct
timeit : 912 lines, 97.9% correct, 10 bad 3-field
tty : 170 lines, 100.0% correct
types : 325 lines, 99.7% correct
uu : 695 lines, 97.8% correct, 2 bad 3-field
wave : 1756 lines, 99.4% correct, 1 bad 3-field
weakref : 1547 lines, 97.8% correct
xdrlib : 1060 lines, 96.1% correct, 39 bad 3-field
