I am trying to run micropython on a OLIMEX STM32-E407 board.
It is similar to the STM32F4 Discovery, so I used this config files as my starting point.
I can build everything, flash the board and start it.
But already in main.c in the main()-function I get always the following error:
"memory allocation failed, heap is locked"
and the program is stuck in the __fatal_error()-function.
most of the time it happens at line 538:
FRESULT res = f_stat(boot_py, NULL);
but sometime also in line 587:
mod_network_init();
I am using the latest code from the github master branch.
Any advice whats going wrong here?
My first try was with this repo
https://github.com/markushx/micropython ... limex-e407
and it worked fine. But since it is very old I will try to port the latest code of micropython to the STM32-E407
Thanks for your help,
stefan
"memory allocation failed, heap is locked" in main.c
Re: "memory allocation failed, heap is locked" in main.c
Finally got it working, had some wrong settings for the clock.
If somebody is also interested in this port, I made a pull request to the official micropython repository
https://github.com/micropython/micropython/pull/2159
