Teensy 3.5 & 3.6 support
Re: Teensy 3.5 & 3.6 support
Postby Roberthh » Thu Dec 01, 2016 8:14 pm
Hello @dhylands. I just stumbled over an issue. When you call
sys.stdin.read(1)
and push Ctrl-C twice, the device locks up. Id does not matter, if you push the Ctrl-C twice in a row or other characters in between. I know it's WIP, so I just wanted to note,
Postby dhylands » Sun Jan 08, 2017 3:23 am
@roberthh - I fixed the Control-C problem, and I think I found the data loss issue.
I rebased to the latest master (1.8.6) and updated the .hex files.
https://github.com/dhylands/micropython/tree/teensy-usb
https://github.com/dhylands/micropython ... /hex-files
I also put a copy of the hex-files here:
https://www.dropbox.com/sh/ubvenq4onpid ... 7x3aa?dl=0
Postby Roberthh » Sun Jan 08, 2017 10:33 am
Hello @dhylands, thank you for the update.
I was able to update my local copy of the repository, compiled & load it, and it seems to work.
I just compared the Ctrl-C handling with sys.stdin.read(1) on the various port, and all behave different.
The behavior I like most is that of the ESP8266 port, in that it interrupts your code, if no exception handler is set, and triggers that handler, if set. and all of that on the first Ctrl-C.
Best Regards, Robert
Postby dhylands » Sun Jan 08, 2017 9:57 pm
Roberthh wrote:Hello @dhylands, thank you for the update.
Currently, that behaviour is determined by code in the stmhal port wihch is shared by the teensy port (so stmhal and teensy both behave the same).
When (softirq's get merged, then I expect we'll see this behaviour become more consistent.
If I had to guess, I would bet that if you called the delay function for several seconds and hit a single Control-C in the middle of the delay, then it won't get processed until the delay actually completes.
Return to “Other Boards”
Who is online
Users browsing this forum: No registered users and 4 guests
