uart lib not found on ESP32 board
jpvic
Postby jpvic » Sun Jan 01, 2017 4:55 pm
I purchased an esp32 board from sparkfun : https://www.sparkfun.com/products/13907
I used the instructions as described on https://github.com/micropython/micropyt ... sp32/esp32 . There is a reference to https://github.com/espressif/esp-idf where you find per-platform the build instructions. I use the Ubuntu on a chromebook ( crouton ) so I followed the detailed documentation on https://github.com/espressif/esp-idf/bl ... -setup.rst.
The build of the code was straight forward and done without error message. The ESP-32 board was flashed easily and I can make the connection and execute the all common python command.
But I can find the uart lib.
>>> import machine
>>> dir(machine)
['__name__', 'mem8', 'mem16', 'mem32', 'freq', 'reset', 'idle', 'time_pulse_us', 'Pin', 'I2C', 'SPI']
I didn't find a compile flag for enabling uart-functionality on esp32 so I would expect it is default.
Can someone give me a hint where I have to look, please?
Regard,
JP
Return to “Other Boards”
Who is online
Users browsing this forum: No registered users and 8 guests
