Page 1 of 2
Downloading, Building and Deploying the Firmware
Posted: Fri Feb 24, 2017 4:59 pm
by SureshVakati
Hello Everyone,
I am new to micropython. I am using STM32F405 in my project. I have deployed micropython into it and wrote some modules. I am including all my modules with in the firmware (Frozen). Now I am trying to add an OTA feature to my project, Can someone help me how can I do it for STM32f4xx? I have cellular modem attached to my processor, so I can download a new firmware from my server using FTP. My question is where should I place that downloaded firmware and how to do update and what format do I have to download (.hex, .dfu or .bin)?
Moderator Note: Please create new topics and don't hijack another topic.
Re: Downloading, Building and Deploying the Firmware
Posted: Fri Feb 24, 2017 7:52 pm
by dhylands
The stmhal doesn't really have a mechanism in place for doing OTA, other than using the bootloader over one of the bootloader supported methods (USB, serial).
The filesystem also isn't big enough to store the firmware image on, so you'd probably need to use an sdcard and also write a bootloader that can update the firmware.
Posted: Fri Feb 24, 2017 11:35 pm
by SureshVakati
Thanks Dave,
I have an SD card connected to my board. My friend has bootloader written in C for STM32F405 which updates his application code Over the Air, Can I use that along with micropython? What is the procedure to do that? How can I change the memory location of Micropython firmware?
Posted: Sat Feb 25, 2017 12:16 am
by dhylands
In your board definition file, (stmhal/boards/BOARDNAME/mpconfigboard.mk) the variable LD_FILE is used to specify the linker script file.
You can provide your own linker script file instead. Note that other parts of the code assume that the filesystem is located from the 16K mark through to the 128K mark. So if the bootloader fits in 16K then you should be able to just modify the linker script.
Posted: Sat Feb 25, 2017 1:49 am
by SureshVakati
Yeah, he mentioned his bootloader just resides with in 16KB.
// Boot Loader resides at 0x08000000..0x08003FFF (16 KB)
// Application resides at 0x08020000..0x0803FFFF (128 KB)
He is configuring so many settings related to the board in his bootloader script (6000 lines of C code), if I use his settings, isn't it gonna conflict with micropython?
"So if the bootloader fits in 16K then you should be able to just modify the linker script." I have no idea what to change here
GNU linker script for STM32F405
/* Specify the memory areas */
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 0x100000 /* entire flash, 1 MiB */
FLASH_ISR (rx) : ORIGIN = 0x08000000, LENGTH = 0x004000 /* sector 0, 16 KiB */
FLASH_TEXT (rx) : ORIGIN = 0x08020000, LENGTH = 0x080000 /* sectors 5,6,7,8, 4*128KiB = 512 KiB (could increase it more) */
CCMRAM (xrw) : ORIGIN = 0x10000000, LENGTH = 0x010000 /* 64 KiB */
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 0x020000 /* 128 KiB */
ENTRY(Reset_Handler)
/* produce a link error if there is not this amount of RAM for these sections */
_minimum_stack_size = 2K;
_minimum_heap_size = 16K;
/* Define tho top end of the stack. The stack is full descending so begins just
above last byte of RAM. Note that EABI requires the stack to be 8-byte
aligned for a call. */
_estack = ORIGIN(RAM) + LENGTH(RAM);
/* RAM extents for the garbage collector */
_ram_end = ORIGIN(RAM) + LENGTH(RAM);
_heap_end = 0x2001c000; /* tunable */
/* define output sections */
SECTIONS
/* The startup code goes first into FLASH */
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
/* This first flash block is 16K annd the isr vectors only take up
about 400 bytes. So we pull in a couple of object files to pad it
out. */
. = ALIGN(4);
*/ff.o(.text*)
*/stm32f4xx_hal_sd.o(.text*)
. = ALIGN(4);
} >FLASH_ISR
/* The program code and other data goes into FLASH */
.text :
. = ALIGN(4);
*(.text*) /* .text* sections (code) */
*(.rodata*) /* .rodata* sections (constants, strings, etc.) */
/* *(.glue_7) */ /* glue arm to thumb code */
/* *(.glue_7t) */ /* glue thumb to arm code */
. = ALIGN(4);
_etext = .; /* define a global symbol at end of code */
} >FLASH_TEXT
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} >FLASH
.ARM :
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
} >FLASH
/* used by the startup to initialize data */
_sidata = LOADADDR(.data);
/* This is the initialized data section
The program executes knowing that the data is in the RAM
but the loader puts the initial values in the FLASH (inidata).
It is one task of the startup to copy the initial values from FLASH to RAM. */
.data :
. = ALIGN(4);
_sdata = .; /* create a global symbol at data start; used by startup code in order to initialise the .data section in RAM */
_ram_start = .; /* create a global symbol at ram start for garbage collector */
*(.data*) /* .data* sections */
. = ALIGN(4);
_edata = .; /* define a global symbol at data end; used by startup code in order to initialise the .data section in RAM */
} >RAM AT> FLASH_TEXT
/* Uninitialized data section */
.bss :
. = ALIGN(4);
_sbss = .; /* define a global symbol at bss start; used by startup code */
*(.bss*)
*(COMMON)
. = ALIGN(4);
_ebss = .; /* define a global symbol at bss end; used by startup code and GC */
} >RAM
/* this is to define the start of the heap, and make sure we have a minimum size */
.heap :
. = ALIGN(4);
PROVIDE ( end = . );
PROVIDE ( _end = . );
_heap_start = .; /* define a global symbol at heap start */
. = . + _minimum_heap_size;
} >RAM
/* this just checks there is enough RAM for the stack */
.stack :
. = ALIGN(4);
. = . + _minimum_stack_size;
. = ALIGN(4);
} >RAM
/* Remove information from the standard libraries */
/DISCARD/ :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
.ARM.attributes 0 : { *(.ARM.attributes) }
I haven't done all these things before, If I understood you correctly, I can compile his code and place it with in that 16k memory and use his bootloader scripts? All I am trying to do is update micropython firmware through his bootloader script.
Posted: Sat Feb 25, 2017 4:21 am
by dhylands
The bootloader would be in the first 16K. The next 112K would be the file system, and micropython would need to start at 0x08020000.
You basically need to merge stm32f405.ld and common.ld into your own .ld file, and change:
.isr_vector :
. = ALIGN(4);
. = ALIGN(4);
} >FLASH_ISR
and change FLASH_ISR to FLASH_TEXT. Theoretically, that's all that needs to change.
Posted: Sat Feb 25, 2017 8:16 pm
by SureshVakati
I followed what you said above.
1.Combined STM32f405.ld and Common.ld into my.ld, here is the entire file after >Flash_ISR to >Flash_TEXT and changed LD_FILE=my.ld from mpconfigboard.mk file
2. I rebuilt the micropython firmware and loaded into the board, while loading I still see memory start point is 0x8000000
MEMORY
SECTIONS
.isr_vector :
. = ALIGN(4);
out. */
. = ALIGN(4);
*/ff.o(.text*)
. = ALIGN(4);
} >FLASH_TEXT
.text :
. = ALIGN(4);
. = ALIGN(4);
} >FLASH_TEXT
.ARM.extab :
} >FLASH
.ARM :
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
} >FLASH
.data :
. = ALIGN(4);
. = ALIGN(4);
.bss :
. = ALIGN(4);
*(.bss*)
*(COMMON)
. = ALIGN(4);
} >RAM
.heap :
. = ALIGN(4);
} >RAM
.stack :
. = ALIGN(4);
. = ALIGN(4);
} >RAM
/DISCARD/ :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
bootloader says application is corrupted. When I look at memory ranges, micropython.hex still shows range from 0x800000.
Here is the bootloader code where it checks application is valid or not. Any inputs?
if (CRC32(0xFFFFFFFF, Size, (void *)APPLICATION_BASE) != 0)
#ifndef SILENT
puts("Application Corrupted");
#endif
return(0);
return(1);
// Generic CRC 32 bit implementation for buffer/stream validation
DWORD CRC32(DWORD Crc, DWORD Size, BYTE *Buffer)
while(Size--)
#if 0
int i;
Crc = Crc ^ (DWORD)*Buffer++;
for(i=0; i<8; i++)
if (Crc & 1)
Crc = (Crc >> 1) ^ 0xEDB88320;
else
Crc = (Crc >> 1);
#else
static const DWORD CrcTable[] = {
0x00000000,0x1DB71064,0x3B6E20C8,0x26D930AC,0x76DC4190,0x6B6B51F4,0x4DB26158,0x5005713C,
0xEDB88320,0xF00F9344,0xD6D6A3E8,0xCB61B38C,0x9B64C2B0,0x86D3D2D4,0xA00AE278,0xBDBDF21C };
Crc = (Crc >> 4) ^ CrcTable[Crc & 0x0F];
#endif
return(Crc);
Posted: Sat Feb 25, 2017 9:49 pm
by dhylands
Here's the steps I did:
cd stmhal/boards
mkdir CUSTOM
cp PYBV10/* CUSTOM
I then edited mpconfigboard.mk to look like:
MCU_SERIES = f4
CMSIS_MCU = STM32F405xx
AF_FILE = boards/stm32f405_af.csv
LD_FILE = boards/CUSTOM/custom.ld
and created CUSTOM/custom.ld to be the combination of stm32f405.ld and common.ld with, changing .isr_vector to point to FLASH_TEXT instead of FLASH_ISR.
I then cd'd back into the stmhal directory and did:
and when it finished, I ran:
672 >readelf -l build-CUSTOM/firmware.elf
Elf file type is EXEC (Executable file)
Entry point 0x804f839
There are 4 program headers, starting at offset 52
Program Headers:
Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align
LOAD 0x008000 0x08020000 0x08020000 0x4e5d8 0x4e5d8 R E 0x8000
LOAD 0x058000 0x20000000 0x0806e5d8 0x00160 0x026a8 RW 0x8000
LOAD 0x05a6a8 0x200026a8 0x0806e738 0x00000 0x04000 RW 0x8000
LOAD 0x05e6a8 0x200066a8 0x0806e738 0x00000 0x00800 RW 0x8000
Section to Segment mapping:
Segment Sections...
00 .isr_vector .text
01 .data .bss
02 .heap
03 .stack
So it seems to be working the way I would expect.
Posted: Sat Feb 25, 2017 10:14 pm
by SureshVakati
I was selecting the wrong file from previous build. I deleted the build folder and re created, now it is showing 0x8020000 but bootloader is still showing application is corrupted. I need to work on bootloader. What should I except, when bootloader points to application memory area? Micropython creates file system and run boot.py and main.py?
Posted: Sun Feb 26, 2017 1:36 am
by dhylands
Not being familiar with your friends bootloader, I'm not sure how or why it would consider that the application is corrupted.
When MicroPython runs for the first time, it should create the filesystem and bootloader.
Does the bootloader update the VTOR registor to point to the new irq vector table location?
