- I wanted to be able to debounce digital inputs in software and run callback functions when the digital inputs changed state.
- I wanted to be able to count pulses from devices like electric meters and water meters, including some debouncing to compensate for reed switch closure bounces.
- I wanted to filter noise out of analog input channels by using a moving average of multiple readings.
- I wanted to read current input values into a data structure that is easy to work with in my data acquistion and controller code.
from inputs import Manager, Digital, Counter, Analog
# List the desired inputs and pass them to a Manager object.
mgr = Manager([Digital('Y1:button1'),
Counter('Y2'),
Analog('X1:sensor1_volts', convert_func=lambda x: x / 4095 * 3.3)])
# The manager object immediately starts polling the inputs after instantiation.
# get a snapshot of all the current input values
vals = mgr.values()
print(vals) # prints the entire dictionary of readings
# prints two individual readings, using normal dictionary access and also
# attribute access.
print(vals['button1'], vals.sensor1_volts, '\n')
time.sleep(1)
