On my Macs, the "first" serial port that shows up is Bluetooth, e.g.
/dev/cu.Bluetooth-Incoming-Port None 0000:0000 None None
/dev/cu.UM34C None 0000:0000 None None
/dev/cu.usbmodem11101 df618c17a781282c 2e8a:0005 MicroPython Board in FS mode
Is there a way to tell mpremote (via the config file?) what the "default" / "fallback" port should be, so that I can do something like mpremote repl without having to specify a port?
Additionally, is there a way to specify help text for aliases set in the config file? I see the commands themselves are pulled in to the output from mpremote --help but it could be useful to define descriptive text to be shown there as well.
general plea for more educational material on the use of mpremote...
