When trying to load purepng "python" library in arduino nano rp2040 connect i am getting the following error.
>>> import png
MemoryError: memory allocation failed, allocating 1016 bytes
Any ideas? How to fix this?
MemoryError when loading python library
Re: MemoryError when loading python library
Are you using https://github.com/Scondo/purepng directly? It's very much not designed for MicroPython.
I found this library which looks like an attempt to minify it somewhat -- https://github.com/Ratfink/micropython- ... ter/png.py
I was trying to adapt https://github.com/Scondo/purepng to micropython. https://github.com/Ratfink/micropython- ... ter/png.py works only partly. It doesn't allow you to write png file.
Thanks,
Thanks,
