mu editor for micropython
Re: mu editor for micropython
Postby pythoncoder » Mon Aug 15, 2016 8:09 am
Fork now supports pasting at the REPL (ctrl-V). So ctrl-E ctrl-V ctrl-D allows code to be pasted in from the editor window or from another application.
Frida
Postby Frida » Mon Aug 15, 2016 8:54 am
poul@poul-S400CA ~/Programmer/mu/mu $ ./run.py
  File "./run.py", line 2, in <module>
    from mu.app import run
  File "/home/poul/Programmer/mu/mu/mu/app.py", line 27, in <module>
    from mu.logic import Editor, LOG_FILE, LOG_DIR
  File "/home/poul/Programmer/mu/mu/mu/logic.py", line 32, in <module>
    from pycodestyle import StyleGuide, Checker
ImportError: No module named 'pycodestyle'
poul@poul-S400CA ~/Programmer/mu/mu $ pycodestyle --version
2.0.0
I'm lost, it say No module named 'pycodestyle', but I have version 2.0.0.
What I lack, one symlink or?
Yes Frida is my watchdog!
Postby pythoncoder » Mon Aug 15, 2016 12:30 pm
Try
$ pip install pycodestyle
You may also need
$ apt-get install pyflakes
These are handy features for checking Python code for style and correctness.
Lornioiz
Postby Lornioiz » Mon Sep 26, 2016 12:41 pm
[quote="pythoncoder"]Fork now supports pasting at the REPL (ctrl-V). So ctrl-E ctrl-V ctrl-D allows code to be pasted in from the editor window or from another application.[/quote]
Hello to everyone!
I'm new to microPython and my knowledge is mostly Python 2.7 (hobbyist level, I wrote some small utility in order to make my work easy, but nothing too fancy).
I wanted to try MU but seems that I got something missing (Python 3.5.2 and Windows). I don't understand what I'm missing:
File "C:\Users\itafiu21\Desktop\mu-master\mu\app.py", line 27, in <module>
File "C:\Users\itafiu21\Desktop\mu-master\mu\logic.py", line 33, in <module>
from mu.contrib import uflash, appdirs, microfs
File "C:\Users\itafiu21\Desktop\mu-master\mu\contrib\microfs.py", line 20, in <module>
from serial.tools.list_ports import comports as list_serial_ports
ImportError: No module named 'serial'
(sorry for the unformatted error, I could not get the code tag to work).
Can anyone tell me what I'm missing here?
Many thanks!
Postby pythoncoder » Mon Sep 26, 2016 3:10 pm
The following dependencies need to be installed, in addition to the ones I mentioned above (pycodestyle and pyflakes):
python3-pyqt5
python3-serial
Hopefully someone with Windows knowledge will be able to tell you how to do this.
Lornioiz
Postby Lornioiz » Mon Sep 26, 2016 5:25 pm
[quote="pythoncoder"]The following dependencies need to be installed, in addition to the ones I mentioned above (pycodestyle and pyflakes):
python3-pyqt5
python3-serial
Hopefully someone with Windows knowledge will be able to tell you how to do this.[/quote]
I got it to work with pyserial, unfortunately it crashes very often.
Tomorrowland I Will try it on macosx.
Thanks a anyway for the help!
Postby pythoncoder » Tue Sep 27, 2016 6:43 am
Well it's standard Python: if it crashes on Windows you could always fix it ;) Does it produce an error report?
I assume you're using my fork? As described above @askvictor's version (and the original) gave the appearance of a hang because the dialog boxes were not properly defined as modal dialogs. The change has been accepted upstream but I don't know if @askvictor is still supporting his fork.
For what it's worth I've used my fork extensively under Linux and it's reliable.
Musikermomo
Postby Musikermomo » Tue Sep 27, 2016 10:37 pm
[quote="pythoncoder"]For what it's worth I've used my fork extensively under Linux and it's reliable.[/quote]
Unfortunately it still says :
[code]Traceback (most recent call last):
File "/home/mofitz/Downloads/mu-master/mu/app.py", line 27, in <module>
File "/home/mofitz/Downloads/mu-master/mu/logic.py", line 30, in <module>
from PyQt5.QtSerialPort import QSerialPortInfo
ImportError: No module named 'PyQt5.QtSerialPort'[/code]
although I'm on a linux-machine and installed all of the dependencies you mentioned.
Any hints?
Postby dhylands » Tue Sep 27, 2016 11:28 pm
It's easy to install the dependencies for the wrong version of python.
For example, under ubuntu, you may have pip, pip2, and/or pip3 depending on which version of ubuntu you're running.
So if you're running python3 you need to make sure that the dependencies are installed for python 3 and not python 2 (and vice-versa).
askvictor
Postby askvictor » Tue Oct 11, 2016 10:31 am
A few fixes pushed :)
Return to “Programs, Libraries and Tools”
Who is online
