mu editor for micropython
rob.frohne
Re: mu editor for micropython
Postby rob.frohne » Thu Dec 29, 2016 5:22 am
Hi Peter, et. al.,
I found for my setup I had to select the fourth element in the serial available_ports array in logic.py, instead of 0, because my esp8266 is at /dev/ttyUSB3. See below:
def find_upython_device():
TODO - allow option to select which serial port to use.
For now, this just returns the first serial port found
available_ports = QSerialPortInfo.availablePorts()
port = available_ports[4]
logger.info('Using port {}'.format(port.portName()))
return port.portName()
except IndexError:
return None
Flashing is not working for me. I'm wondering if that is because nobody has modified the flashing to work with the esp8266 yet, or if it is for a similar reason to the problem I fixed above. Sorry if this is a newbie question. I'm rather new to python.
Thanks,
Rob
askvictor
Postby askvictor » Sun Jan 01, 2017 11:24 am
rob.frohne wrote:Hi Peter, et. al.,
Yeah, the serial port selection is scrappy. Ideally it would try to autodetect, but that's harder than it sounds, and also, few computers have multiple (or, indeed, any) serial ports these days, so 0 is a good guess for most cases.
Flashing through mu is not yet implemented - its only there for the micro:bit at this stage.
rcolistete
Postby rcolistete » Sun Jan 01, 2017 11:53 am
Have you seen this video ?
Blockly for MicroPython in the browser and in Mu
December 8th 2016
A quick overview of work in progress concerning the use of blocks, MicroPython, the BBC micro:bit and the browser based editor and Mu
https://www.youtube.com/watch?v=XCZEKtNHx5k
Postby pythoncoder » Mon Jan 02, 2017 8:54 am
Impressive!
In a lighter vein I was struck by his statement "I've also made sure that not everything you can do with the Microbit is available in blocks. Some of the really cool more complicated features to do with the microbit you can only access using Python."
Doubtless that required a great deal of effort and attention to detail. You wouldn't want to reduce the entirety of software engineering to shifting blocks around, now would you? ;)
rcolistete
Postby rcolistete » Fri Jan 13, 2017 10:36 pm
rcolistete wrote:Have you seen this video ?
December 8th 2016
You can test a local web Python Editor for BBC Micro:bit with Blocks using the source code :
https://github.com/bbcmicrobit/PythonEditor
It is easy :
$ git clone https://github.com/bbcmicrobit/PythonEditor.git
$ cd PythonEditor
$ git submodule update --init --recursive
Then double click 'editor.html'.
Return to “Programs, Libraries and Tools”
Who is online
Users browsing this forum: No registered users and 2 guests
