pymakr on Arch Linux, not working yet
torwag
Post by torwag » Thu Sep 22, 2016 1:10 pm
I tried to install pymakr under Arch Linux. After converting the deb package into an Arch-package, I had some dependency problems. Some small version mismatch of bash-completion and another package. I removed those dependencies checks and continued to install pymakr.
It installed however, starting pymakr showed that I missed python-pyqt4. After installing this. pymakr starts however, no I receive a strange error message:
cannot import name QLabel.
Here is the entire message:
An unhandled exception occurred. Please report the problem
using the error reporting dialog or via email to <support@pycom.io>.
A log has been written to "/home/torsten/.pymakr/pymakr_error.log".
Error information:
2016-09-22, 15:06:49
<type 'exceptions.ImportError'>:
  File "/usr/share/pymakr/modules/pymakr.py", line 368, in <module>
    main()
  File "/usr/share/pymakr/modules/pymakr.py", line 288, in main
    from UI.SplashScreen import SplashScreen, NoneSplashScreen
  File "/usr/share/pymakr/modules/UI/SplashScreen.py", line 16, in <module>
    from PyQt5.QtGui import QPixmap, QColor, QLabel
Version Numbers:
  Python 2.7.12
  Qt 5.7.0
  PyQt 5.7
  sip 4.18.1
  QScintilla 2.9.3
  WebKit 538.1
  Pymakr 1.0.0.b3
Platform: linux2
2.7.12 (default, Jun 28 2016, 08:31:05)
[GCC 6.1.1 20160602]
Distribution Info:
  /etc/arch-release
  /etc/os-release
  NAME="Arch Linux"
  ID=arch
  PRETTY_NAME="Arch Linux"
  ANSI_COLOR="0;36"
  HOME_URL="https://www.archlinux.org/"
  SUPPORT_URL="https://bbs.archlinux.org/"
  BUG_REPORT_URL="https://bugs.archlinux.org/"
I believe I installed all necessary libs. Maybe it is a mismatch in versions not sure.
Did someone install pymakr already under Arch Linux?
mfgeorge
Re: pymakr on Arch Linux, not working yet
Post by mfgeorge » Sat Nov 05, 2016 4:47 pm
Hello torwag,
I am having the same trouble here as well. I have tried numerous approaches.
I have installed by converting the .deb package
also by git cloning the source and compiling the ui files and running from the folder.
I then went in to the UI/SpashScreen.py file and changed the QLabel import from the QtGui to QtWidgets, as I read that it was available there.
However, after attempting to run the program again I receive a different type of error:
BackgroundService listening on: 36121
[1] 25202 segmentation fault (core dumped) python2 pymakr.py
File "Utilities/BackgroundClient.py", line 193, in <module>
backgroundClient.run()
File "Utilities/BackgroundClient.py", line 178, in run
'EXCEPTION', '?', [str(exctype), str(excval), tbinfo])
File "Utilities/BackgroundClient.py", line 81, in __send
self.connection.sendall(header)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 32] Broken pipe
At this point I decided to uninstall all the qt5 bindings, and attempt to get up and running using qt4. This got me further, where a dialog error box from the GUI came up reporting that I did not have qt installed. I verified that I did have qt4 and all of the bindings installed. I then decided to do a fresh install of python into a python virtualenv and attempt running from there with qt4. But got the very same results, with the GUI window popping up saying that I didn't have qt installed.
For now, I feel I have exhausted enough options trying to use the IDE. I have read they don't have monospace fonts, so I am not sure how enjoyable it would be anyways. If something comes up and I figure out how to get it installed, I will let you know.
For now, you can load the pyCom boards with firmware using the FTP server that it comes with, if you haven't figured this out already.
Let me know if you figure anything else out regarding pymakr!
Lysenko
Post by Lysenko » Sat Nov 05, 2016 6:52 pm
  Qt 5.7.0
  PyQt 5.7
[/quote]
In Qt5.x the QLabel class lives in QtWidgets. It was in QtGui in Qt4.x.
Post by Roberthh » Sat Nov 05, 2016 8:57 pm
I had also some trouble installing pymakr on my debian machine. I had both qt4 and qt5 installed, and that broke pymakr, which relies on Qt4. After removing Qt5 from my PC, pymakr worked. But pymakr is definitely not finished, not even close.
