Hi I'm new and just managed to compile a tweaked firmware for the ESP8266.
I want to add certain files into the filesystem by default and have this flashed at the same time as the firmware.
Is there a way to add such a filesystem so that it is flashed with the firmware, or what is the best way to do this without having to have a second step of uploading files? Thanks.
Flashing firmware with filesystem
Re: Flashing firmware with filesystem
I think the easiest, even though a bit hacky, way is to simply flash your firmware, upload the files you need, and then dump the whole flash back with esptool.py.
The contents of the files that are created when the filesystem is initialized are directly included in the source as char arrays. I did a PR once for stmhal to create those arrays from actual files in the source tree, but there were some doubts about merging it and I never persued the issue.
https://github.com/micropython/micropython/pull/1891
Maybe you can use that as a starting point.
It would be nice if there was a /flash folder in /esp8266 which, on make, would append each file to the flash filesystem.
Then we would have 3 methods for deploying scripts, /scripts, /modules and /flash.
