I wanted to tap all the members who have gone through the manual building of MicroPython for the ESP8266. What I am looking for is the best way to build the custom firmware. I am interested in approaches that would make building a custom MicroPython image, not so cumbersome.
Anyway, the only approach I know is to manually follow the jumbled collection of documentation and build the firmware step by step.
Any new ideas would be welcome to. Thanks!
Joe
Viable Options To Simplify the Custom Firmware Build Process
Re: Viable Options To Simplify the Custom Firmware Build Process
you can use a script like I do in my project: https://github.com/kevinkk525/pysmartno ... ository.sh
(there are also some board definitions and sync scripts. So I just need to execute the build script and it syncs my project files and builds the firmware).
Kevin Köck
Here is an alternative. As you'll see, mine assumes that the build system is installed, it just streamlines the process of repetitive builds.
Thanks for the responses!
I guess I should narrow down the topic to be more in line with what I was thinking.
What I am really looking for is a simple, start with nothing, procedure/application/package that goes something like this...
Any thoughts on my concept?
- Install small toolset of scripts with maybe a small GUI
- Download a prebuilt VirtualBox appliance targeting a specific ESP8266 version (ex. v1.17)
- Specify your frozen modules
- Kick off a process that eventually spits out a MicroPython bin
I don't understand the problem this aims to solve. If it is installing the toolchain then anyone who feels inclined could build a Linux VM with the toolchain and distribute that. That could be useful to beginners.
The rest of the process really isn't "cumbersome". Put the files to be frozen in the right directory, run a script like mine, and it gets built and written to the device. As a command line process it's about as simple as it could possibly be. I guess a GUI would simplify this marginally. But enough to justify the time taken writing it?
Have you tried building the ESP_OPEN_SDK lately? (https://github.com/pfalcon/esp-open-sdk) It doesn't work. Versions have been updated, files have been moved... it is very difficult... and I've done it many times before!
What I am trying to do is make building the ESP8266 port not such a hassle. If you don't see any value in that... well I guess you don't need it.
As I said above, a VM with the toolchain installed would be useful. A VM would arguably be easier to use than the README suggestion of docker.
It's the ideas beyond, e.g. of a GUI, that which puzzle me, as the process of freezing modules is straightforward.
Another Approach
Although I have only seen the idea in passing here in the forums, it strikes me as a solution that might work for a small subset of users... especially beginners.
The idea is to have an online service that consists of a simple set of pages used to specify the makeup of a simple MicroPython binary. I would start with compiling ESP8266 binaries to be simple.
Of course this simple proof-of-concept could be greatly enhanced...
Anyway... chime in please if you have any thoughts on the idea. (BTW... I happen to be a web developer by profession)
Joe
- Select Base Version (ex. 1.17)
- Select Frozen Modules To Add (ex. sdcard.py)
- Future Ports
- Preservation of manifest configurations
- Multiple frozen modules sources
- Direct upload
- General URL specification
- MicroPython/lib reference - Named/Branded Versions
Joe
- uPyBuilder Architecture (draft)
- uPyBuilder Architecture.png (137.86 KiB) Viewed 16947 times
