when I connect my ESP8266 board to my home MacBook Air it's not being "recognised" at all. I don't see any new device in /dev/*
If I connect the board on my work MacBook Pro instead it's recognised and available on /dev/tty.SLAB_USBtoUART
They are both running latest OSX (10.11.3)
I can't find any explanation for that and the only suspect I have is that MacBook Air doesn't give enough power to the board so it's not able to be mounted.
Which commands could I try on my MacBook Air to understand if the device is recognised by the system at all?
Thank you so much, cheers.
Huzzah ESP8266 not recognised on a MacBook Air
- andreagrandi
- andreagrandi
Re: Huzzah ESP8266 not recognised on a MacBook Air
I resolved the problem! I tried installing this driver: https://www.silabs.com/products/mcu/Pag ... ivers.aspx
because that's what I found searching for the device I see when the board is connected:
after installing the driver I was able to connect to the board:
➜ pydojo ioreg -p IOUSB -w0 | sed 's/[^o]*o //; s/@.*$//' | grep -v '^Root.*'
BRCM20702 Hub
Bluetooth USB Host Controller
USB Optical Mouse
CP2104 USB to UART Bridge Controller
MicroPython v1.6-150-gd973c1b on 2016-03-07; ESP module with ESP8266
>>> print('Hello MicroPython!')
Hello MicroPython!
Thanks for sharing andreagrandi. Have you installed the driver using the package manager or fetched them from the silicon labs?
A note on the USB to UART capability check can be included in the official documentation too. I don't remember having to do that on my linux machine however.
- andreagrandi
Hi,platforma wrote:Thanks for sharing andreagrandi. Have you installed the driver using the package manager or fetched them from the silicon labs?
I installed the package downloading it from the link I previously posted.
Cheers
