to build the toolchain on OSX (El Capitan) but I'm getting this error:
Now configured for "xtensa-lx106-elf"
sed -r -i.org s%CT_PREFIX_DIR=.*%CT_PREFIX_DIR="/Volumes/case-sensitive/esp-open-sdk/xtensa-lx106-elf"% .config
sed -r -i s%CT_INSTALL_DIR_RO=y%"#"CT_INSTALL_DIR_RO=y% .config
cat ../crosstool-config-overrides >> .config
./ct-ng build
[INFO ] Performing some trivial sanity checks
[INFO ] Build started 20160306.210216
[INFO ] Building environment variables
[INFO ] =================================================================
[INFO ] Retrieving needed toolchain components' tarballs
[INFO ] Retrieving needed toolchain components' tarballs: done in 359.00s (at 06:02)
[INFO ] Extracting and patching toolchain components
[INFO ] Extracting and patching toolchain components: done in 143.00s (at 08:26)
[INFO ] Installing GMP for host
[INFO ] Installing GMP for host: done in 73.00s (at 09:39)
[INFO ] Installing MPFR for host
[INFO ] Installing MPFR for host: done in 30.00s (at 10:09)
[INFO ] Installing ISL for host
[INFO ] Installing ISL for host: done in 36.00s (at 10:45)
[INFO ] Installing CLooG for host
[INFO ] Installing CLooG for host: done in 12.00s (at 10:57)
[INFO ] Installing MPC for host
[INFO ] Installing MPC for host: done in 12.00s (at 11:09)
[INFO ] Installing binutils for host
[INFO ] Installing binutils for host: done in 82.00s (at 12:31)
[INFO ] Installing pass-2 core C compiler
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstddef:46:9: error: no member named 'ptrdiff_t' in the global namespace
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iterator:413:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iterator:440:56: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iterator:756:66: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/iterator:756:54: error: template parameter missing a default argument
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:755:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:903:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1522:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1550:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1580:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1644:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1736:13: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1833:23: error: use of undeclared identifier 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1835:65: error: expected class name
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1850:12: error: use of undeclared identifier 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1851:22: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1853:16: error: use of undeclared identifier 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1854:11: error: unknown type name 'ptrdiff_t'
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memory:1854:29: error: use of undeclared identifier 'ptrdiff_t'
[ERROR] fatal error: too many errors emitted, stopping now [-ferror-limit=]
[ERROR] /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/memoryfatal error:: too many errors emitted, stopping now [-ferror-limit=]
[ERROR] 1522:13: error: unknown type name 'ptrdiff_t'
[ERROR] make[4]: *** [graphite.o] Error 1
[ERROR] make[4]: *** [graphite-blocking.o] Error 1
[ERROR] make[4]: *** [graphite-clast-to-gimple.o] Error 1
[ERROR] make[3]: *** [all-gcc] Error 2
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing pass-2 core C compiler'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@216]
[ERROR] >> called from: do_cc_core_backend[scripts/build/cc/gcc.sh@483]
[ERROR] >> called from: do_cc_core_pass_2[scripts/build/cc/gcc.sh@153]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@638]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'share/doc/crosstool-ng/ct-ng.1.20.0/B - Known issues.txt'
[ERROR]
[ERROR] (elapsed: 14:40.00)
[14:41] / make[2]: *** [build] Error 1
make[1]: *** [_toolchain] Error 2
make: *** [/Volumes/case-sensitive/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc] Error 2
