- Bug with PULL_NONE in onewire.py/neopixel.py drivers. Fixed in master, either rebuild from source, or dowload the latest versions from https://github.com/micropython/micropyt ... 66/scripts , rename to onewire_.py/neopixel_.py, and use as "import onewire_ as onewire".
- Debug logging from ESP8266 RTOS is not disabled by default. It's actually helpful for starters to confirm/diagnose how the module connects with your access point, etc., but may interfere with production use. To disable it, execute "esp.osdebug(None)". If you want to do that automatically on boot, it should be added in boot.py of the internal filesystem.
Version 1.8 ERRATA
Version 1.8 ERRATA
Unfortunately, beyond the known issues as described in the release notes for 1.8, we have some bugs sneak in. This topic tracks them and known workarounds, as well as status of the other known issues too.
Awesome MicroPython list
