Hi!
I tried to implement a webserver that serves files from the filesystem. (html, css, js)
If the files are bigger then 10k, character are lost and the browser receives incomplete data.
For example i sended a file with 46.279 Bytes and the browser only receives 38.747 Bytes. I did a compare with "Beyond Compare" and it is not just the end of the file that is missing, there are holes.
I am using a NodeMCU board and the esp8266-20161017-v1.8.5.bin micropython image.
To verify my code, I tried other webserver and run into the same problem.
Does anyone have any idea why that happens?
This is the method that sends the file back to the browser:
def sendfile(socket, filename):
....print("Filename: {0}".format(filename))
....header = '''HTTP/1.0 200 OK\r\nContent-type: text/html\r\n\r\n'''
....socket.send(header)
....with open(filename, 'rb') as f:
........while True:
.............buffer = f.read(256)
.............if not buffer:
................break
.............print("Send buffer")
.............socket.send(buffer)
Webserver looses character
Re: Webserver looses character
Why not test the return value of send which is supposed to be the actual number of bytes sent ? Well I assume that's the case. The MicroPython docs don't say as much.
Try socket.sendall(buffer)
Yes, socket.sendall(buffer) solved the problem.
Ah, "socket.send()" stands for "send as much you want."
Thanks!
Thanks!
That's what I use. I favor that. Should not loose a single byte...Roberthh wrote:Try socket.sendall(buffer)
