Today I compiled 'MicroPython v1.8.6-9-g30cfdc2 on 2016-11-13' to Esp and installed uqmtt.robust using upip. This installation created files robust.py and simple.py at /lib/umqtt/ dir as expected. But when I tried to import robust I got:
>>> from umqtt import robust
File "/lib/umqtt/robust.py", line 4, in <module>
AttributeError: 'module' object has no attribute 'MQTTClient'
and this is because of robust.py line 2: 'from . import simple'.
KeyError: __main__
It seams that mycropython doesn't recognize this dot as a current directory because this way I succeeded to import robust.py:
>>> from umqtt import simple
error when trying to use "from . import"
Re: error when trying to use "from . import"
I suggest you raise an issue against micropython-lib https://github.com/micropython/micropython-lib.
