TMP100 library - Please critique
Re: TMP100 library - Please critique
Post by pythoncoder » Tue Jan 03, 2017 7:56 am
ernitron wrote:...as performance is concern I think the bitwise operation is faster...
Well, temperatures usually change slowly ;) Presumably your concern is the CPU time spent doing the read.
If so, bear in mind that floating point operations imply memory allocation. Also that multiplying by 0.0625 is the same as a sign-extended 4 bit right shift - albeit with the latter discarding fractional degrees. The best solution is application dependent; but for most practical purposes I'd probably stick with one of the floating point approaches.
