i have an arduino ESP8266 running as server with the below details. The arduino is streaming some sensor data at 100 Hz rate.
IPAddress ipServer(192,168,4,1);
IPAddress ipClient(192,168,4,10);
IPAddress Subnet(255,255,255,0);
I am running a Python code on a PC whose IP address is 192.168.4.10 and is on the same subnet. i am able to ping 192.168.4.1 and get 0% packet loss. So the connection is working. When attempting to bind a socket, I get no response and it timesout.
Wondering if someone could help me with this?
thanks - V
The python code on the PC is here
from socket import *
HOST = "192.168.4.1"
PORT = 9047
address = (HOST, PORT) #Defind who you are talking to (must match arduino IP and port)
client_socket = socket(AF_INET, SOCK_DGRAM) #Set Up the Socket
#client_socket.bind((HOST, PORT))
client_socket.settimeout(5) #only wait 1 second for a response
while(1): #Main Loop
rec_data, addr = client_socket.recv(100) #Read response from arduino
print rec_data #Print the response from Arduino
sleep(10/1000000) # sleep 10 microseconds
UDP data reception through Python running on a PC
Re: UDP data reception through Python running on a PC
I think you may be a bit confused about how UDP communication works. In UDP there are no connections, just senders and receivers.
In your set up, if the arduino is "streaming" (i.e. sending) data, it is the UDP sender and it must know the IP address (and listening port) of your the receiver (your PC). It simply opens a socket and uses socket.sendto() (or the equivalent of the Arduino API) to send UDP packet to the receiver.
The PC is the receiver and must open a socket, bind to the address and port used in the sento() calls by the sender (arduino), e.g. the external IP of your PC and port 9047 in your example, and then use socket.recvfrom() to receive UDP datagrams from any client, which sends to this address and port.
In your code, HOST should not be the address of the sender (arduino), but the address of the PC. And you need to use socket.recvfrom() instead of socket.recv().
This is all assuming, the arduino code is really "streaming" data, as you say, i.e. sending it via UDP. But it really uses UDP, it makes not much sense otherwise, since you can't easily connect to a server and request the data.
Or maybe I misunderstood your setup completely. In this case, please provide the relevant arduino code, so we can see what the esp does.
