If yes, then why are ports e.g. on Huzzah Feather labeled as SDA and SCL, if that not really matters?
What is the highest speed that was found to be reliable in a set-up with short wires, 4k7 pull-up and clean signals on the bus?
The reason I ask: I have a test set-up, which seems to fail after a while at clock rate of 100 kHz.
File "sh1106.py", line 96, in write_cmd
OSError: [Errno 19] ENODEV
