Now i reached 0,15 sec for each transaction.
Duration of 1000 cycles of data transmission from a PC to ESP8266
sockets - 146 sec
JSON serialization - 2 sec
lamps toggling - 1.5 sec
Is this slow MicroPython socket realisation or ESP8266 WiFi or something else...
Perhapse UDP will be a little fester?
In MP documentation mentioned IPPROTO_UDP
https://docs.micropython.org/en/latest/ ... ocket.html
but i got error:
object has no attribute 'socket.IPPROTO_UDP'
Just cant find worked UDP example for MicroPython.
---------------------TCP ----------------------------
simple server on an ESP8266:
Sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
Sock.bind( ("0.0.0.0.0", 50000)
Sock.listen(1)
Conn, Addr = Sock.accept()
while (True):
Data = Conn.recv(512)
if (Data):
...JSON serialization
...Lamps toggling
Conn.send('get ' + Data)
Conn.close()
Sock.close()
