Is the method shown here the recommended method of setting the registers to allow reading the A/D value of the VCC pin, or has this now been integrated into the firmware ??
https://github.com/micropython/micropython/issues/2352
import esp
from flashbdev import bdev
ADC_MODE_VCC = 255
ADC_MODE_ADC = 0
def set_adc_mode(mode):
sector_size = bdev.SEC_SIZE
flash_size = esp.flash_size() # device dependent
init_sector = int(flash_size / sector_size - 4)
data = bytearray(esp.flash_read(init_sector * sector_size, sector_size))
if data[107] == mode:
return # flash is already correct; nothing to do
data[107] = mode # re-write flash
esp.flash_erase(init_sector)
esp.flash_write(init_sector * sector_size, data)
print("ADC mode changed in flash; restart to use it!")
return
>>> import machine
>>> vcc = machine.ADC(1)
>>> vcc.read()
2973
