Debugging wifi connectivity
amartino
Post by amartino » Fri Feb 24, 2017 9:27 am
Hi there,
I've suddenly experienced that most all three ESP8266 boards (WeMod D1 mini) have stopped connecting to the Wifi. Below is the code, stripped to the network related parts, that was successfully used to connect before:
ap_if = network.WLAN(network.AP_IF)
ap_if.active(False)
sta_if.active(True)
sta_if.connect('o2-WLAN42', '94796AV9436KQQN3')
while not sta_if.isconnected(): pass
print('Connected to wireless')
I'm checking in parallel that there wasn't something changes with the access point, though all my other devices aren't having issues connecting.
>>> sta_if.active()
True
>>> sta_if.status()
4
>>> sta_if.ifconfig()
('0.0.0.0', '0.0.0.0', '0.0.0.0', '208.67.222.222')
False
>>> sta_if.scan()
[(b'CORRECT-SSID', b'L\t\xd4,\x82\x9a', 10, -89, 3, 0)]
The status description can be found https://docs.micropython.org/en/latest/ ... twork.html. Based on that, the reason the connection is failing (4) is:
STAT_CONNECT_FAIL – failed due to other problems
Tried to see what kind of error would Arduino give. Ended up with a similar
WL_CONNECT_FAILED = 4
Ref. https://github.com/esp8266/Arduino/blob ... initions.h
  • Could you please point me to the source for the network module?
  • Other suggestions how to approach the problem from the esp8266 side.
amartino
Re: Debugging wifi connectivity
Post by amartino » Sun Feb 26, 2017 1:17 pm
I've just discovered something peculiar :)
The code below:
led = machine.Pin(D1, machine.Pin.OUT)
button = machine.Pin(D0, machine.Pin.IN)
ap_if.active(False)
sta_if.active(True)
sta_if.connect('my-SSID', 'my-password')
    time.sleep_ms(1000)
    print("Still connecting to Wireless")
client = MQTTClient("esp-reciever", "192.168.1.142")
time.sleep_ms(1000)
client.connect()
once_presset = False
    time.sleep_ms(20)
    if button.value() == 1 and once_pressed == False:
        led.value(1)
        client.publish(b"/lopy", b"Button on")
        once_pressed = True
        print
    if button.value() == 0 :
        led.value(0)
        once_pressed = False
Manages to kill my routers ability to accept new devices into the WiFi network. Once I restart the router new devices can again be connected. I've copied the exact same code with which I managed to cause it. Will update once I have the filtered reason.
Will try to set a dedicated AP on my laptop to see whats happening on the other side.
