timezone support in MicroPython ?
Re: timezone support in MicroPython ? DST/EST
def dstTime():
year = time.localtime()[0] #get current year
# print(year)
HHMarch = time.mktime((year,3 ,(14-(int(5*year/4+1))%7),1,0,0,0,0,0)) #Time of March change to DST
HHNovember = time.mktime((year,10,(7-(int(5*year/4+1))%7),1,0,0,0,0,0)) #Time of October change to EST
# print(HHNovember)
now=time.time()
if now < HHMarch : # we are before last sunday of march
dst=time.localtime(now-18000) # EST: UTC-5H
elif now < HHNovember : # we are before last sunday of october
dst=time.localtime(now-14400) # DST: UTC-4H
else: # we are after last sunday of october
return(dst)
# print(year)
# print(HHNovember)
now=time.time()
return(dst)
Easiest way I found is changing ntptimes internal NTP_DELTA Variable, so it calculates it right.
Run ntptime.settime() after boardinit to have the correct time before execution.
Get tuple afterwards with utime.localtime()
def getntptime(timer):
year = utime.localtime()[0] #get current year
now=ntptime.time()
HHMarch = utime.mktime((year,3 ,(31-(int(5*year/4+4))%7),1,0,0,0,0,0)) #Time of March change to CEST
HHOctober = utime.mktime((year,10,(31-(int(5*year/4+1))%7),1,0,0,0,0,0)) #Time of October change to CET
ntptime.NTP_DELTA = 3155673600-3600 # CET: UTC+1H
elif now < HHOctober : # we are before last sunday of october
ntptime.NTP_DELTA = 3155673600-7200 # CEST: UTC+2H
ntptime.settime() # set the rtc datetime from the remote server
Great workaround!kwtf wrote: ↑Fri Apr 03, 2020 10:14 amEasiest way I found is changing ntptimes internal NTP_DELTA Variable, so it calculates it right.
def getntptime(timer): year = utime.localtime()[0] #get current year now=ntptime.time() HHMarch = utime.mktime((year,3 ,(31-(int(5*year/4+4))%7),1,0,0,0,0,0)) #Time of March change to CEST HHOctober = utime.mktime((year,10,(31-(int(5*year/4+1))%7),1,0,0,0,0,0)) #Time of October change to CET if now < HHMarch : # we are before last sunday of march ntptime.NTP_DELTA = 3155673600-3600 # CET: UTC+1H elif now < HHOctober : # we are before last sunday of october ntptime.NTP_DELTA = 3155673600-7200 # CEST: UTC+2H else: # we are after last sunday of october ntptime.NTP_DELTA = 3155673600-3600 # CET: UTC+1H ntptime.settime() # set the rtc datetime from the remote server
Please, can you tell why I get this error:
" File "ntptime.py", line 35, in settime
OverflowError: overflow converting long int to machine word"
When I run it on my ESP 8266 NODEMCU?
Thanks for your time!
Same error here.
What firmware are you guys using? I can't replicate this with firmware built today.
kwtf,
Thanks for posting your solution.
Unfortunately, NZ change back to NZST on the first Sunday in April at 3AM, which left me wondering if:
would be correct. I couldn't find any Google hits on what appears to be a "magic" formula:
Did find some information suggesting that Robert Harry van Gent was responsible for the CET forumlaes but searched all around his website without finding out how to calculate the mday number.
Can someone post a link to how to work this out?
Thanks.
HHApril = utime.mktime((year,4,(7-(int(5*year/4+4))%7),3,0,0,0,0,0))
Thanks.
the timzone had not bothered me with my projects until i made a neopixel clock and we switched to daylight savings recently.
So this is what I have come up with for my timezone calculations based on the input from the earlier posts by davef and enzo
The different months, March, April, September and October / first and last sunday all have a different offsets based so you will need to play around with those for your timezone. This has have been check against https://www.timeanddate.com/ for the NZ timezone up to 2030.
there is probably some additions that could be included but this met my needs for now
https://en.wikipedia.org/wiki/List_of_UTC_time_offsets
https://www.iana.org/time-zones
I basically run this code on boot, and once a day to keep the RTC in sync correctly
# Set RTC localTime from UTC and apply DST offset
# Requires import machine, utime, ntptime
# assumes active network, otherwise will raise error whch is not currently dealt with
# Note: dstOffset should be between -12 and +14
def setLocalTime ( dstOffset ):
# get the YEAR to use in calculation
year, month, day, hour, minute, second, ms, dayinyear = utime.localtime()
if year < 2020:
# probably just booted, so get the time for calculation
now=ntptime.time()
# reload current time
# szTime = "{:4}-{:02}-{:02} {:02}:{:02}:{:02}".format( year, month, day, hour, minute, second )
# print( "Time : " , szTime )
# define DST change dates for this year
# NZDT Starts : 2:00 Last Sunday September
dstDT = utime.mktime((year, 9, (30 -(int(5*year/4+4))%7),2,0,0,0,0,0)) #Time of September change to NZDT
# NZST Starts : 3:00 1st Sunday April
dstST = utime.mktime((year, 4, ( 7 -(int(5*year/4+5))%7),3,0,0,0,0,0)) #Time of April change to NZST
if dstOffset >= 0 : #
# print( "Positive DST timezones" )
if now > dstST and now < dstDT:
# print( "Standard Time")
ntptime.NTP_DELTA = 3155673600-( dstOffset * 3600)
# print( "Daylight Time")
ntptime.NTP_DELTA = 3155673600-( (dstOffset+1) * 3600)
# print( "Negative DST timezones" )
if now > dstDT and now < dstST :
# set the RTC to correct time
ntptime.settime()
# year, month, day, hour, minute, second, ms, dayinyear = utime.localtime()
# print( "setTime : " , szTime )
I made this for Finland. I fixed second last in date tuple to 6, because 0 is Monday. TIMEZONE_DIFFERENCE is normal (winter) time difference, like 2 for Finland.Stephen Betts wrote: ↑Thu Oct 22, 2020 8:38 amthe timzone had not bothered me with my projects until i made a neopixel clock and we switched to daylight savings recently.
# ###################################################################### # # Set RTC localTime from UTC and apply DST offset # Requires import machine, utime, ntptime # assumes active network, otherwise will raise error whch is not currently dealt with # Note: dstOffset should be between -12 and +14 # ###################################################################### # def setLocalTime ( dstOffset ): # get the YEAR to use in calculation year, month, day, hour, minute, second, ms, dayinyear = utime.localtime() if year < 2020: # probably just booted, so get the time for calculation now=ntptime.time() # reload current time year, month, day, hour, minute, second, ms, dayinyear = utime.localtime() # szTime = "{:4}-{:02}-{:02} {:02}:{:02}:{:02}".format( year, month, day, hour, minute, second ) # print( "Time : " , szTime ) # define DST change dates for this year # NZDT Starts : 2:00 Last Sunday September dstDT = utime.mktime((year, 9, (30 -(int(5*year/4+4))%7),2,0,0,0,0,0)) #Time of September change to NZDT # NZST Starts : 3:00 1st Sunday April dstST = utime.mktime((year, 4, ( 7 -(int(5*year/4+5))%7),3,0,0,0,0,0)) #Time of April change to NZST if dstOffset >= 0 : # # print( "Positive DST timezones" ) if now > dstST and now < dstDT: # print( "Standard Time") ntptime.NTP_DELTA = 3155673600-( dstOffset * 3600) else: # print( "Daylight Time") ntptime.NTP_DELTA = 3155673600-( (dstOffset+1) * 3600) else: # print( "Negative DST timezones" ) if now > dstDT and now < dstST : # print( "Standard Time") ntptime.NTP_DELTA = 3155673600-( dstOffset * 3600) else: # print( "Daylight Time") ntptime.NTP_DELTA = 3155673600-( (dstOffset+1) * 3600) # set the RTC to correct time ntptime.settime() # year, month, day, hour, minute, second, ms, dayinyear = utime.localtime() # szTime = "{:4}-{:02}-{:02} {:02}:{:02}:{:02}".format( year, month, day, hour, minute, second ) # print( "setTime : " , szTime )
Global dst_on is needed for Suntime calculation, perhaps I change it so that timezone is not actually needed.
def resolve_dst_and_set_time():
global TIMEZONE_DIFFERENCE
global dst_on
# This is most stupid thing what humans can do!
# Rules for Finland: DST ON: March last Sunday at 03:00 + 1h, DST OFF: October last Sunday at 04:00 - 1h
# Sets localtime to DST localtime
if network.WLAN(network.STA_IF).config('essid') == '':
now = mktime(localtime())
if DEBUG_ENABLED == 1:
print("Network down! Can not set time from NTP!")
now = ntptime.time()
(year, month, mdate, hour, minute, second, wday, yday) = localtime(now)
if year < 2020:
print("Time not set correctly!")
return False
dstend = mktime((year, 10, (31 - (int(5 * year / 4 + 1)) % 7), 4, 0, 0, 0, 6, 0))
dstbegin = mktime((year, 3, (31 - (int(5 * year / 4 + 4)) % 7), 3, 0, 0, 0, 6, 0)))
if TIMEZONE_DIFFERENCE >= 0:
if (now > dstbegin) and (now < dstend):
dst_on = True
ntptime.NTP_DELTA = 3155673600 - ((TIMEZONE_DIFFERENCE + 1) * 3600)
dst_on = False
ntptime.NTP_DELTA = 3155673600 - (TIMEZONE_DIFFERENCE * 3600)
if (now > dstend) and (now < dstbegin):
dst_on = False
dst_on = True
if dst_on is None:
print("DST calculation failed!")
return False
ntptime.settime()
npttime.settime() error overflow converting long int to machine wordpythoncoder wrote: ↑Wed Aug 19, 2020 12:45 pmWhat firmware are you guys using? I can't replicate this with firmware built today.
with ESP32, sys.version = 3.4.0
esp32-idf4-20200902-v1.13.bin
How to repeat? Execute multiple times ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
>>> ntptime.settime()
File "ntptime.py", line 39, in settime
>>> ntptime.settime()
File "ntptime.py", line 25, in time
OSError: [Errno 110] ETIMEDOUT
>>> ntptime.settime()
>>> ntptime.settime()
Not related to ntphosts:
>>> ntptime.host = 'test.nothin.com'
>>> ntptime.settime()
File "ntptime.py", line 20, in time
OSError: -202
NTP time not set! Error -202
File "main.py", line 322, in resolve_dst_and_set_time
ValueError:
ValueError:
ValueError:
>>> ntptime.host = 'pool.ntp.org'
>>> ntptime.settime()
>>> ntptime.settime()
>>> localtime()
(2021, 2, 28, 10, 30, 40, 6, 59)
trying this:
n = 0
while (settime_complete is False) and (n <= 20):
if n >= 20:
f4.write("npttime.settime() tried 20 times. Giving up\n")
f4.close()
reset()
ntptime.settime()
except Exception as e:
n += 1
# npttime.settime() error overflow converting long int to machine word
f4.write("npttime.settime() error %s\n" % e)
sleep(10)
settime_complete = True
Hi Divergentti,
Sorry I missed this. I had a lot of grief getting ntptime on the ESP32. Finally ended up doing this:
boot.py
which calls:
then:
main.py
which calls:
getUTC.py
and finally my datalogger program runs.
I see the ESP32 try to connect 5 and then connects on the 2nd try in the 2nd call. I am connecting to a Huwaei hotspot so maybe you will need to go through different "hoops" to get consistent connection. If I don't stop at 5 attempts it just keeping trying to connect. It appears I need to try between 3-5 times before doing the machine.reset().
Snippets of information picked up from Peter Hinch and RobertHH.
Good luck or have you sorted it by now.
P.S. something else quite important I think sometimes you get an error when ntptime() is called that it not obvious to me. A software watchdog timer sorts that out or the system freezes.
boot.py
# This file is executed on every boot (including wake-boot from deepsleep)
#import network
import esp
esp.osdebug(None)
from wifi_functions import connect
import gc
connect()
gc.collect()
import utime
def connect():
# connect to the internet
count = 0
if not sta_if.isconnected():
print('connecting to hotspot...')
sta_if.active(True)
sta_if.ifconfig(('192.168.10.99', '255.255.255.0', '192.168.10.1', '8.8.8.8'))
sta_if.connect('HUAWEI-E8231-c4fd', 'your password')
while (count < 5):
count += 1
status = sta_if.status()
with open('errors.txt', 'a') as outfile:
outfile.write('connect status = ' + str(status) + '\n')
except OSError:
print('oops')
if (sta_if.isconnected()):
count = 0
break
print('.', end = '')
utime.sleep(1)
if (count == 5):
count = 0
outfile.write('did NOT connect to internet' + '\n')
except OSError:
print('oops')
machine.reset()
print(' network config:', sta_if.ifconfig())
main.py
from getUTC import getntptime
import utime
import webrepl
import gc
from watchdog_timer import wdt_callback
from watchdog_timer import wdt_feed
wdt_callback()
getntptime()
# found that waiting for awhile, especially if
# NOT making a static connection helps to remove
# a OSError [Errno 110] TIMEOUT error in ntptime.py
print('waiting 5 seconds')
utime.sleep(5)
wdt_feed()
webrepl.start()
gc.collect()
import logger
getUTC.py
import ntptime
import utime
def getntptime():
now = 0
ntptime.host = 'nz.pool.ntp.org'
count = 0
while (count < 10):
count += 1
except OSError as error:
machine.reset()
utime.sleep(1)
if (now > 660000000):
count = 0
break
if (count == 10):
count = 0
machine.reset()
print(' got epoch')
utime.sleep(1)
# only correct for 2021 New Zealand
HHApril = utime.mktime((2021,4,4,3,0,0,0,0,0)) # time of April change to NZST
HHSept = utime.mktime((2021,9,26,2,0,0,0,0,0)) # time of Sept change to NZDT
if now < HHApril: # we are before the first Sunday of April
ntptime.NTP_DELTA = 3155673600 - (13 * 3600) # NZDT: UTC-13H
elif now < HHSept: # we are before the last Sunday of Sept
ntptime.NTP_DELTA = 3155673600 - (12 * 3600) # NZST: UTC-12H
else: # we are after the last Sunday of Sept
# set the time
count = 0
while (count < 10):
count += 1
my_time = ntptime.settime() # set the rtc datetime from the remote server
utime.sleep(1)
if (str(my_time) == 'None'):
count = 0
break
if (count == 10):
count = 0
machine.reset()
print(' time has been set')
utime.sleep(1)
