Esp32 firmware 1.17 with spiram WIFI issue
eldstado
Post by eldstado » Fri Oct 29, 2021 10:42 am
Hi
I've been using firmware 1.14 with spiram build on IDF 3.x and its been working fine on esp32 wrover-b.
After updating to v 1.17 build on idf 4.x there is some problems using WIFI. if router uses default DHCP_LEASE time (7200 secs) the board looses connection exactly every hour(half the lease time) and reboots(my code)
if I set another dhcp_lease time, it works okay. For example if I set lease time on router to 3600 it works as it should.
Any idea why?
eldstado
Re: Esp32 firmware 1.17 with spiram WIFI issue
Post by eldstado » Fri Feb 04, 2022 1:15 pm
Still same issue om v18. Nobody else seeing this problem?
