Hello Team,
Can someone clarify me if there is any option to use micropython with any Ethernet module?
I read multiple topics on this forum and what I found is that micropython doesn't work with ETH modules because it's made to use Wi-Fi interface. Is it true?
Also, I cannot understand why in the latest micropython version 1.17, I cannot import this module:
https://docs.micropython.org/en/latest/ ... ght=wiznet
Best Regards, Joan
ESP32 + Wiznet 5500 or Ethernet module
Re: ESP32 + Wiznet 5500 or Ethernet module
There are ports and boards with Ethernet. Only it has to be part of the firmware image.
Hi, I've done some test with a ESP32-WROVER-IE and an external SPI Wiznet5500 ethernet chip. After a lot of research on this forum and github, I've decided to try to modify a pure-python adafruit driver for this chip. Now it seems works.
Please, could you:
1. Share the source code Wiznet5500 driver?
2. Do you know if SSL/TLS works on sockets using the Wiznet5500?
Thank you.
Hi, I've already share it in another post:
viewtopic.php?f=2&t=5851&p=67272#p67272
You have to copy files (without the folder) on your micro and run `esp32_eth_wiznet5500_ntp.py` script to test the NTP server with the WIZNET5500.
Let's my know if it works!
Esp32 supports Mac ,can realize wired network with a PHY
I have implemented in this git repo
Please check https://github.com/Ayyoubzadeh/Micropyt ... 0--Wiznet-
