After starting './install.sh' I see:
Then it starts installing xtensa tools, butat some point it fails withDetecting the Python interpreter
Checking "python" ...
Python 3.10.4
"python" has been detected
Installing ESP-IDF tools
Current system platform: linux-amd64
WARNING: File /home/rob/.espressif/idf-env.json was not found.
Creating /home/rob/.espressif/idf-env.json
What is the reason for the 'permission denied' (never saw it in previous installs)Creating a new Python environment in /home/rob/.espressif/python_env/idf4.4_py3.10_env
ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/usr/local/lib/python3.10/dist-packages/distutils-precedence.pth'
Consider using the `--user` option or check the permissions.
RuntimeError: failed seed with code 1
The consideration to use of '--user' option is unclear: where?
Suggestions?
Regards, Rob.
