Can I use this wiki to work with the ESP32 http://docs.micropython.org/en/latest/e ... ckref.html
And is it possible to upload a pythonscript from Windows to the ESP32, for example I like to try the wifi.
ESP32 documentation
Re: ESP32 documentation
Until there is a matching documentation, the one for the esp8266 should give the best match. But you have to try. For uploading scripts to the device you can use all USB based tools, like rshell, ampy, mpfshell, or what you find on the board. There is no official support for telnet or ftp (yet). If you build your own image, you can place your favorite scripts into flash as frozen bytecode. Just put the into the modules directory and run build & flash.
