def boot():
global mcp, mqtt
# 5 : D1 : SDL
# 4 : D2 : SDA
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=10000)
mcp = mcp9808.MCP9808(i2c=i2c)
mcp.set_resolution(mcp9808.T_RES_AVG)
mqtt = MQTT(config.MQTT_ADDR)
mqtt.connect()
def run():
global mcp, mqtt
temp = mcp.get_temp()
print(temp)
mqtt.publish("/temperature", temp)
for _ in range(1, 55):
# for cntrl C to work via tty
time.sleep(1)
import socket
import binascii
except ImportError:
import ubinascii as binascii
import config
class MQTT(object):
s = None
addr = None
prefix = ""
def __init__(self, host, port=1883, prefix=config.MQTT_PREF):
self.addr = socket.getaddrinfo(host, port)[0][4]
self.prefix = prefix
self.reset_socket()
def reset_socket(self):
self.s = socket.socket()
def connect(self):
address = self.addr
self.s.connect(address)
self.s.send(self.mtpConnect(config.DEVICE_NAME))
def disconnect(self):
self.s.send(self.mtpDisconnect())
self.s.close()
def publish(self, topic, data, sleep=1):
self.s.send(self.mtpPub(self.prefix+topic, bytes(str(data), 'ascii')))
if sleep:
time.sleep(sleep)
def recv(self, length=4096):
return binascii.hexlify(self.s.recv(length))
@staticmethod
def mtStr(s):
return bytes([len(s) >> 8, len(s) & 255]) + s.encode('utf-8')
@staticmethod
def mtPacket(cmd, variable, payload):
return bytes([cmd, len(variable) + len(payload)]) + variable + payload
def mtpConnect(self, name):
return self.mtPacket(
0b00010000,
self.mtStr("MQTT") + # protocol name
b'\x04' + # protocol level
b'\x00' + # connect flag
b'\xFF\xFF', # keepalive
self.mtStr(name)
@staticmethod
def mtpDisconnect():
return bytes([0b11100000, 0b00000000])
def mtpPub(self, topic, data):
return self.mtPacket(0b00110001, self.mtStr(topic), data)
connected with 0x43, channel 6
dhcp client start...
STAT_CONNECTING
STAT_CONNECTING
STAT_CONNECTING
ip:192.168.178.12,mask:255.255.255.0,gw:192.168.178.1
23.0
23.0
23.0
23.0
