out of memory
gratefulfrog
Re: out of memory
Post by gratefulfrog » Sat Aug 13, 2016 12:48 pm
ok, I'm an idiot...
Fixed by:
$ sudo apt-get install python-usb
gratefulfrog
Re: out of memory
Post by gratefulfrog » Sat Aug 13, 2016 1:15 pm
And now, the results!!!
Remember, prior to the byte compiling and frozen code, I could not allocate an instance of the App at the REPL.
Now, with the byte compiled code loaded in flash:
MicroPython v1.8.2-89-gb67eb20 on 2016-08-13; PYBv1.0 with STM32F405RG
>>> import gc
>>> gc.collect()
>>> gc.mem_free()
102064
>>> from app import App
>>> a=App()
>>> gc.mem_free()
68448  # total cost import + allocation: 33.6KB
So, I can now finish the coding and try the system!!!
Thanks so much to all you guys!
Ciao,
Bob
gratefulfrog
Re: out of memory
Post by gratefulfrog » Thu Aug 25, 2016 8:30 pm
Well, I'm back with yet another challenge related to the byte-compiling and importing from flash.
I am now facing an unexpected hindrance in my devt. cycle.
This is what happens:
  • I have 20 or so .py files that I byte compile and load into flash. These files embed a dependency hierarchy.
  • I would like to continue devt. on one of the files, so I put it on the sd-card.
  • I change the sys.path to ['/sd', '/sd/lib', '/flash', '/flash/lib']
  • Now, if I import the file, I get the sd-card version.
  • However, if the file itself imports other files, then these cannot be found unless they appear on the sd-card as well.
  • This means, that all the files need to be on the sd-card and then I run out of memory as before.
I don't understand why the import mechanism doesn't follow the sys.path and look for the modules on flash??
It works properly on linux:
file a.py is in ~/Desktop
# file a.py
import b
def f(x):
    return b.g(x)
file b.py is in ~/.micropython/lib
# file b.py
def g(x):
    print('I did g!')
    return x+1
Running micropython from ~/Desktop, it works fine:
~/Desktop$ micropython
Micro Python  on 2015-05-11; linux version
>>> import sys
>>> sys.path
['', '/home/bob/.micropython/lib', '/usr/lib/micropython']
>>> import a
>>> a.f(12)
I did g!
13
But on the pyboard, with b.py compiled into flash, it says module b is not found.
Is this normal behavior or a bug?
Thanks for your thoughts!
Ciao,
Bob
Re: out of memory
Post by pythoncoder » Fri Aug 26, 2016 6:10 am
Perhaps I'm not following you here, but I thought you were using frozen bytecode. If you put foo.py into your frozen directory, compile the firmware, and load it you can issue
import foo
from any of your modules and the frozen version will be found in preference to any other version regardless of the path. They don't live in /flash which refers to the specific filesystem on the built-in flash memory: they inhabit a region of flash memory outside of any explicit filesystem.
While developing I work as follows. I don't change the path. I implement "stable" modules as frozen bytecode, put the "development" modules on the SD card and ignore the built in flash. Obviously once you've got a stable working system you might choose to freeze everything except boot.py and main.py. These might live in flash so you could run without the SD card.
gratefulfrog
Re: out of memory
Post by gratefulfrog » Fri Aug 26, 2016 9:47 am
@pythoncoder
Thank you for your response.
Further exploration has lead me to understand the sys.path variable and to discover an error in my previous post.
I have done some further experimenting with these files:
Frozen a.py:
# FROZEN file a.py
import b
def f(x):
    print('I am FROZEN in A!')
    return b.g(x)
Frozen b.py:
# FROZEN file b.py
def g(x):
    print('I am FROZEN in B!')
    return x+1
SD-Card a.py
# SD-CARD file a.py
import b
def f(x):
    print('I am A on the SD Card!')
    return b.g(x)
NOTE: b.py is NOT present on the SD-Card.
Now look at this sequence:
>>> import a
>>> a.f(10)
I am FROZEN in A!
I am FROZEN in B!
11
PYB: sync filesystems
PYB: soft reboot
MicroPython v1.8.2-89-gb67eb20 on 2016-08-26; PYBv1.0 with STM32F405RG
>>> import sys
>>> sys.path
['', '/flash', '/flash/lib', '/sd', '/sd/lib']
>>> sys.path[1] = sys.path[0]
>>> sys.path[0] = sys.path[3]
>>> sys.path
['/sd', '', '/flash/lib', '/sd', '/sd/lib']
>>> import a
>>> a.f(20)
I am FROZEN in B!
21
I conclude that the sys.path '' (empty string) refers to the FROZEN code and the other elements refer to what one would expect.
That means one can put under-work files on the sd-card and use them in collaboration with the frozen code by appropriately setting the sys.path variable, which is exactly what I wanted!
This interaction has made my life a lot better!
Thanks for your help!
Ciao,
Bob
Re: out of memory
Post by pythoncoder » Fri Aug 26, 2016 4:02 pm
Interesting and unexpected (by me). Yet os.listdir('') lists the contents of the SD card and always seems to yield the same result as os.listdir('/sd').
Re: out of memory
Post by dhylands » Fri Aug 26, 2016 6:12 pm
The magic seems to be here:
https://github.com/micropython/micropyt ... #L114-L127
that loop is where it enumerates sys.path and if a path element has a non-zero length then it prepends the path element and a slash to the name of the module.
So if your path was ['', '/sd', '/sd/lib'] then it would look for 'foo', '/sd/foo', and '/sd/lib/foo'.
stat_dir_or_file then tries some variations (using as is (covers case of directory with __init__.py), adding .py, adding .mpy
and mp_import_stat_any checks for frozen modules.
So, yes - it looks like the empty string in sys.path determines where it searches for frozen modules.
I think it would be useful to have a way of determining what frozen files exist. It seems like it could be done as some type of virtual filesystem, but that feels way too heavy to me.
I think adding a function that just returns a tuple of names would be useful, especially from a debugging context.
Re: out of memory
Post by pythoncoder » Sat Aug 27, 2016 5:42 am
dhylands wrote:...I think adding a function that just returns a tuple of names would be useful, especially from a debugging context.
Great idea!
