Page 1 of 2
Is it possible for micro:bit to support multiple languages?
Posted: Sun Jan 01, 2017 3:12 pm
by Jason Kim
example)
I am Korean.
so i want write that "microbit.display.scroll("안녕하세요"); <- this is Korean.
Is it possible to make the output available in the desired language?
Re: Is it possible for micro:bit to support multiple languages?
Posted: Sun Jan 01, 2017 11:41 pm
by deshipu
Micro:Bit has very limited memory, and the default font that it uses only covers the basic ASCII characters. Supporting the full Unicode range is pretty much out of question in this situation. You can, however, display and scroll those characters as images (as long as you manage to squeeze them into the 5x5 grid).
Posted: Mon Jan 02, 2017 1:39 am
by Jason Kim
@deshipu
thank you for reply.
Can you tell me which module I need to modifiy if i wnat to print the other language as images?
One more thing, What's the amount of memory that Micro:Bit has? So can not support all the Unicode?
Thank you very much.
Posted: Mon Jan 02, 2017 9:45 am
by deshipu
You can refer to the documentation about displaying and scrolling images:
http://microbit-micropython-pl.readthed ... image.html
You can read about the technical specs of the Micro:bit on the official page here:
http://microbit.org/hardware/ and in the reference specification here:
http://tech.microbit.org/hardware/#nrf5 ... -processor
Posted: Mon Jan 02, 2017 9:58 am
by deshipu
For example, I tried to make the "안녕하세요" text:
from microbit import Image, Display
image = Image(
"0900900900990090090009009090099900:"
"9090990990990999090009009090900090:"
"0900900999990090099090999090099900:"
"0000000900090909090090909090090900:"
"9999000999990090090090909090999990:")
def scroll(image):
for x in range(image.width):
yield image.crop(x, 0, 5, 5)
Display.show(scroll(image))
(I didn't test it, but it should give you an idea.)
Note how the characters are practically completely unreadable on the 5x5 display -- the Hangul glyphs are too complex to display properly at this resolution.
Posted: Mon Jan 02, 2017 10:55 am
by rcolistete
I think that only the new 2017 Micro:bit version will support asian characters :
The Micro:bit Foundation wants to help 'tens of millions' of children to code
The Foundation has been created by the BBC, ARM, Microsoft, Nominet, Samsung and the Institution of Engineering and Technology, and wants to reach 100 million people
http://www.wired.co.uk/article/microbit ... ft-samsung
But that isn't enough, Shelby says
a new version of the micro:bit could come as soon as 2017. This would help it to keep up with technological developments and also
make it compatible for use elsewhere in the world. Shelby says: "We have a lot more processor power coming".
"We're going to see more capabilities in regional support. We need bigger screens to be able to do Chinese and Japanese characters when we've been going out and using it in Asia," he explains.
Posted: Tue Jan 03, 2017 5:38 am
by Jason Kim
@deshipu Thank you for your response.
Thank you for the code you upload for me. and There are question about the code.
I changed the code slightly.
so i tried again.
from microbit import *
image = Image(
"090900:"
"090909:"
"090909:"
"090909:"
"090909:")
def my_scroll(image) :
for x in range(image.width()) :
yield image.crop(x, 0, 5, 5) <- understand!
display.show(my_scroll(image))
and then result is
Allocation in interrupt handlerTraceback (most recent all last):
File "<stdin>", line 15, in <module>
MemoryError
why is that happen to me....
Posted: Tue Jan 03, 2017 11:52 am
by deshipu
I think I see the problem. Looks like the scroll iterator is getting executed inside an interrupt (makes sense, so that it it can scroll while other code is running), but inside an interrupt you are not allowed to allocate memory. However, the crop method creates an new image, allocating memory -- so it fails. I'm sorry, I didn't test this code before (there were a lot of spelling errors in it too), and I didn't think about this limitation.
The documentation actually warns about this:
http://microbit-micropython.readthedocs ... #functions
Posted: Tue Jan 03, 2017 12:06 pm
by Jason Kim
@deshipu Thank you for reply.
I'm okay because I am learning a lot of thing about Micro:bit by you!
thank you a lot!
so, Is there any other way to solve this problem?
This is very basic and important to what I'm trying to do. If this problem is resolved, it will be modified to support all Unicode. I'd appreciate it if you could help me with this problem.
p.s I will upload again so that all people can see this problem. thank you so much deshipu
Posted: Tue Jan 03, 2017 12:14 pm
by deshipu
Here's a fixed program, that works around the memory allocation issue by manually copying the pixels from the original image into a new image. This time I tested it.
image = Image(
"090900:"
"090909:"
"090909:"
"090909:"
"090909:")
window = Image(5, 5)
for position in range(-4, image.width() + 1):
for y in range(5):
for x in range(5):
window.set_pixel(x, y, image.get_pixel(x + position, y) if 0 <= x + position < image.width() else 0)
yield window
display.show(my_scroll(image), wait=False)
