urequests post stopped working
brett
Post by brett » Sun Jan 15, 2017 3:56 am
I'm very new to micropython and python. I've been trying to get the ESP8266 to work with pushingbox. The following code worked for awhile but stopped working today.
[code]import machine
import urequests
url_14 = 'http://api.pushingbox.com/pushingbox?de ... xxxxxxxxxx'
# Buttons
button14 = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_UP)
led = machine.Pin(2, machine.Pin.OUT)
first = button14.value()
time.sleep(0.01)
second = button14.value()
if first and not second:
print('Button pressed!')
led(0)
elif not first and second:
print('Button released!')
led(1)
resp = urequests.post(url_14)[/code]
I get the following error when I run the script:
File "<stdin>", line 22, in <module>
File "urequests.py", line 104, in post
File "urequests.py", line 51, in request
OSError: -2
Any help would be greatly appreciated.
brett
Re: urequests post stopped working
Post by brett » Tue Jan 17, 2017 12:20 am
I'm an idiot...I forgot that I reflashed the board but didn't reconnect it to the wiFi :roll:
kfricke
Post by kfricke » Tue Jan 17, 2017 8:56 am
Side note: This is an example where the assumption that the ESP automagically will connect to a WLAN can be a bad design decision.
Considering the need to erase the flash when upgrading makes it worse.
brett
Post by brett » Mon Jan 23, 2017 1:40 am
Ok...thanks to pythoncoder I got a working program, but I'm having urequests issues again. The post under emergencyRequest works fine but the posts under helpRequest just pauses for a second or two and then the function completes. It seems like it is trying to send it but it doesn't go through. I've tested the url by entering url_01 under emergencyRequest and it works. I've also tried getting rid of everything in the helpRequest function except the urequests post and it still doesn't work. Any thoughts on what is going on?
import urequests
wlan.active(True)
wlan.connect('xxxxxxxxxxx', 'xxxxxxxx')
button = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_UP)
redled = machine.Pin(5, machine.Pin.OUT)
yelled = machine.Pin(12, machine.Pin.OUT)
grnled = machine.Pin(4, machine.Pin.OUT)
url_01 = 'http://api.pushingbox.com/pushingbox?devid=xxxxxxxxxxxxxx'
url_02 = 'http://api.pushingbox.com/pushingbox?devid=xxxxxxxxxxxxxx'
buttonCounter = 0
def helpRequest():
    if buttonCounter == 1:
        resp = urequests.post(url_01)
        print('Help 1')
        yelled(1)
        tim = Timer(-1)
        tim.init(period=10000, mode=Timer.ONE_SHOT, callback=lambda t:yelled(0))
    elif buttonCounter == 2:
        print('Help 2')
        yelled(1)
        tim = Timer(-1)
def emergencyRequest():
    print('Emergency')
    resp = urequests.post(url_02)
    redled(1)
    tim2 = Timer(1)
    tim2.init(period=10000, mode=Timer.ONE_SHOT, callback=lambda t:redled(0))
def buttonReset(self):
    helpRequest()
    global buttonCounter
    buttonCounter = 0
    print('reset')
    print(buttonCounter)
    first = button.value()
    time.sleep(0.05)
    second = button.value()
        buttonCounter = buttonCounter + 1
        tim3 = Timer(2)
        tim3.init(period=2000, mode=Timer.ONE_SHOT, callback=buttonReset)
    if buttonCounter >= 3:
        emergencyRequest()
        buttonCounter = 0
    if wlan.isconnected() == True:
        grnled(1)
    elif wlan.isconnected() == False:
        grnled(0)
Post by deshipu » Mon Jan 23, 2017 10:38 am
I don't think you can do requests from inside of interrupts.
brett
Post by brett » Mon Jan 23, 2017 11:29 am
I was thinking that but the emergency one works. Is that an interrupt?
Post by deshipu » Mon Jan 23, 2017 12:39 pm
The emergency one is being called from the main loop. The help one is called from a timer interrupt.
brett
Post by brett » Mon Jan 23, 2017 12:43 pm
Ahhhh....OK...I will see what I can do about that this evening. Thanks for helping this newb learn!!
brett
Post by brett » Thu Feb 23, 2017 2:03 am
Ok…I’m still struggling. The program will send both a help request and an emergency request. Where it gets weird is when you make 5 consecutive activations of combinations of help and emergency requests.
I’ve tried these combinations:
Help, help, help, help, help
Emergency, help, help, help, help
Help, emergency, emergency, emergency, emergency
Emergency, help, Emergency, help, Emergency
Help, emergency, help, emergency, help
After these combinations I get the following error message:
File "main.py", line 61, in <module>
OSError: -2
After the second emergency request I get the following error message:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 32028, room 16
tail 12
chksum 0x40
ho 0 tail 12 room 4
load 0x3ffe8000, len 1092, room 12
tail 8
chksum 0x17
load 0x3ffe8450, len 3000, room 0
tail 8
chksum 0x56
csum 0x56
Any thoughts and suggestions? Here is the current code:
import urequests
wlan.active(True)
wlan.connect('xxxxxxxxxxxx', 'xxxxxxxxxx')
url_01 = 'http://api.pushingbox.com/pushingbox?devid=xxxxxxxxxxxxxxx'
buttonCounter = 0
helpFlag = False
def helpRequest():
        global helpFlag
        helpFlag = True
        global helpFlag
        helpFlag = True
    print('Emergency')
    redled(1)
    tim2 = Timer(1)
    helpRequest()
    buttonCounter = 0
    print('reset')
    time.sleep(0.05)
        tim3 = Timer(2)
        emergencyRequest()
        buttonCounter = 0
    if helpFlag == True:
        helpFlag = False
        print('Help 2')
        yelled(1)
        tim = Timer(-1)
        grnled(1)
        grnled(0)
