I want to log a few hours of RH data from an Si7021 sensor using my PyBoard v1.1, I can't get my microSD card to work with it for the moment - which is why I'm writing to flash (shouldn't be a problem for the time being?).
I wrote some dirty python to do the job, as below:
from pyb import I2C
i2c = I2C(1)
i2c = I2C(1, I2C.MASTER)
i2c.init(I2C.MASTER, baudrate=100000)
log = open('/flash/RHlog.csv', 'w')
i2c.send(0xF5, 0x40)
[x, y] = i2c.recv(2, 0x40)
RH_val = (x<<8) | y
RH = ((125*RH_val)/65536)-6
t = pyb.millis()
log.write('{},{}\n'.format(RH,t))
pyb.delay(2000)
It works fine when I send it line by line over the REPL, it makes RHlog.csv on the flash and writes a new line each time with the RH value and time (millis). But when I save it as a main.py on the board all I get is a boot error (red and green LED flash alternately). Can't seem to fix it by any means.
Anyone know what I'm doing wrong? Why the code won't work? Maybe I should just write the sensor output to file directly and do the math (conversion) later?
Thanks.
Datalogging RH from Si7021, can't get my code to work
Re: Datalogging RH from Si7021, can't get my code to work
What I normally do is to put my code in a file, say rshlog.py and make sure I can do: from the REPL and not get any errors.
Then I just add the import rshlog line to main.py. You're much less likely to make an error adding an import statement than adding a bunch of code.
import rshlog
