I am attempting to associate the ROM of a DS18X20 with a dictionary so that I can identify it.
First thing I noticed is that onewire.py sometimes prepends a '(' to the byte array.
Second problem is I am unable to select the dictionary ds_roms using the parsed rom id.
Running this on python2 succeeds on https://repl.it/FLDY but refuses to work on upython.
The device is WIPY2 with latest firmware.
ds_roms = {
"(\xff\xfe\x88\x84\x16\x03\xd1":"living_room",
"\x10\xe5x\xd5\x01\x08\x007":"bed_room"
devices = [bytearray(b'(\xff\xfe\x88\x84\x16\x03\xd1'), bytearray(b'\x10\xe5x\xd5\x01\x08\x007')]
for device in devices:
DEV = str(bytes(device)).replace("'",'').strip('b')
print(ds_roms[DEV])
DS18X20 rom ID lookup
Re: DS18X20 rom ID lookup
WiPy2 is supported on the Pycom Forum https://forum.pycom.io/.
String in python will use ASCII characters whenever possible. So the string '(\xff' is really the same thing as '\x28\xff'. If you want the string to always be hex, you can use ubinascii.hexlify:
MicroPython is based on Python 3, and this has some changes to the way strings and bytestrings work. "abc" is a string and b'abc' is a byte string. If your keys are strings then you can't use byte strings as lookups or vice-versa. So this works:. Because strings are utf-8 encoded, you probably shouldn't try to convert the ROM ids into strings since they may contain invalid utf-8 sequences. If you have a string which only contains ASCII characters, then you can convert a byte string into a string by using: So if you used the hex string version of the ROM id then you could do:
Hopefully that will give you some ideas about how to deal with this.
>>> import ubinascii
>>> id = b'(\xff\xfe\x88\x84\x16\x03\xd1'
>>> ubinascii.hexlify(id)
b'28fffe88841603d1'
ds_roms = {
b"(\xff\xfe\x88\x84\x16\x03\xd1":"living_room",
b"\x10\xe5x\xd5\x01\x08\x007":"bed_room"
print(ds_roms[bytes(device)])
>>> x = b'abc'
>>> str(x, 'utf-8')
'abc'
import ubinascii
ds_roms = {
'28fffe88841603d1':"living_room",
'10e578d501080037':"bed_room"
dev_key = str(ubinascii.hexlify(device), 'utf-8')
print(ds_roms[dev_key])
Dave, thanks so much for helping with this, and for such a comprehensive explanation.
That certainly works and is much more concise than the work around method I came up with
Cheers
Cheers
