hallo
a good day
i have a problem
i have this code, this code is using a DHT11
but, the code give me this mistake
OSError: [Errno 110] ETIMEDOUT
i have the last version firmware
this is mi code
>>> import machine
>>> import dht
>>> d = dht.DHT11(machine.Pin(0))
>>> d.measure()
File "dht.py", line 13, in measure
i hope can are help me
DHT11 don't work
Re: DHT11 don't work
Can you describe how you have wired up things?
Also, use a forum search for "DHT11", there are several threads with hints on how to use this module.
thanks
I'll do that
I'll do that
