Hi Folks
Anyone's help would be much appreciated. I'm getting this error and cannot figure why: AttributeError: type object 'Timer' has no attribute 'B'
I have installed: https://github.com/wipy/wipy/blob/maste ... lynkLib.py.
In Pymakr I get:
Running boot.py
I (58882) wifi: sleep enable
I (58883) wifi: type: 1
I (58883) wifi: mode : sta (24:0a:c4:00:af:c8)
I (61966) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
I (62941) wifi: state: init -> auth (b0)
I (62943) wifi: state: auth -> assoc (0)
I (62955) wifi: state: assoc -> run (10)
I (62966) wifi: connected with Air2, channel 6
('192.168.0.102', '255.255.255.0', '192.168.0.1', '0.0.0.0')
MicroPython v1.8.6-422-g516b861 on 2017-02-07; WiPy with ESP32
Running main.py
File "<stdin>", line 24, in <module>
File "/flash/lib/BlynkLib.py", line 126, in <module>
File "/flash/lib/BlynkLib.py", line 127, in HwPin
main.py code:
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Blynk community: http://community.blynk.cc
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to perform periodic actions and
update the widget value on demand.
In your Blynk App project:
Add a Value Display widget,
bind it to Virtual Pin V2,
set reading frequency to 'PUSH'.
Run the App (green triangle in the upper right corner).
Don't forget to change WIFI_SSID, WIFI_AUTH and BLYNK_AUTH
import BlynkLib
BLYNK_AUTH = 'my blynk thing goes here'
# initialize Blynk
blynk = BlynkLib.Blynk(BLYNK_AUTH)
# register the task running every 3 sec
# (period must be a multiple of 50 ms)
def my_user_task():
# do any non-blocking operations
print('Action')
blynk.virtual_write(2, time.ticks_ms() // 1000)
blynk.set_user_task(my_user_task, 3000)
# start Blynk (this call should never return)
blynk.run()
BlinkLib.py code
#!/usr/bin/env python3
# Micro Python library that brings out-of-the-box Blynk support to
# the WiPy. Requires a previously established internet connection
# and a valid token string.
# Example usage:
# import BlynkLib
# import time
# blynk = BlynkLib.Blynk('08a46fbc7f57407995f576f3f84c3f72')
# # define a virtual pin read handler
# def v0_read_handler():
# # we must call virtual write in order to send the value to the widget
# blynk.virtual_write(0, time.ticks_ms() // 1000)
# # register the virtual pin
# blynk.add_virtual_pin(0, read=v0_read_handler)
# # define a virtual pin write handler
# def v1_write_handler(value):
# print(value)
# blynk.add_virtual_pin(1, write=v1_write_handler)
# # register the task running every 3 sec
# # (period must be a multiple of 50 ms)
# def my_user_task():
# # do any non-blocking operations
# print('Action')
# blynk.set_user_task(my_user_task, 3000)
# # start Blynk (this call should never return)
# blynk.run()
# This file is part of the Micro Python project, http://micropython.org/
# The MIT License (MIT)
# Copyright (c) 2015 Daniel Campora
# Copyright (c) 2015 Volodymyr Shymanskyy
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
# THE SOFTWARE.
import socket
import struct
import os
except ImportError:
import MachineStub as machine
const = lambda x: x
import wipy
except ImportError:
import WiPyStub as wipy
HDR_LEN = const(5)
HDR_FMT = "!BHH"
MAX_MSG_PER_SEC = const(20)
MSG_RSP = const(0)
MSG_LOGIN = const(2)
MSG_PING = const(6)
MSG_TWEET = const(12)
MSG_EMAIL = const(13)
MSG_NOTIFY = const(14)
MSG_BRIDGE = const(15)
MSG_HW_SYNC = const(16)
MSG_HW_INFO = const(17)
MSG_HW = const(20)
STA_SUCCESS = const(200)
HB_PERIOD = const(10)
NON_BLK_SOCK = const(0)
MIN_SOCK_TO = const(1) # 1 second
MAX_SOCK_TO = const(5) # 5 seconds, must be < HB_PERIOD
WDT_TO = const(10000) # 10 seconds
RECONNECT_DELAY = const(1) # 1 second
TASK_PERIOD_RES = const(50) # 50 ms
IDLE_TIME_MS = const(5) # 5 ms
RE_TX_DELAY = const(2)
MAX_TX_RETRIES = const(3)
MAX_VIRTUAL_PINS = const(32)
DISCONNECTED = 0
CONNECTING = 1
AUTHENTICATING = 2
AUTHENTICATED = 3
EAGAIN = const(11)
def sleep_from_until (start, delay):
while time.ticks_diff(start, time.ticks_ms()) < delay:
machine.idle()
return start + delay
class HwPin:
_TimerMap = { 'GP9': (2, machine.Timer.B),
'GP10': (3, machine.Timer.A),
'GP11': (3, machine.Timer.B),
'GP24': (0, machine.Timer.A),
'GP25': (1, machine.Timer.A)}
_HBPin = 25 if 'WiPy' in os.uname().machine else 9
def __init__(self, pin_num, mode, pull):
self._mode = mode
self._pull = pull
self._function = ''
self._pin = None
self._apin = None
self._pwm = None
pin_num = int(pin_num)
self._name = 'GP' + str(pin_num)
if pin_num == HwPin._HBPin:
wipy.heartbeat(False)
def _config(self, duty_cycle=0):
if self._function == 'dig':
_mode = machine.Pin.OUT if self._mode == 'out' else machine.Pin.IN
if self._pull == 'pu':
_pull = machine.Pin.PULL_UP
elif self._pull == 'pd':
_pull = machine.Pin.PULL_DOWN
_pull = None
self._pin = machine.Pin(self._name, mode=_mode, pull=_pull, drive=machine.Pin.MED_POWER)
elif self._function == 'ana':
adc = machine.ADC(bits=12)
self._apin = adc.channel(pin=self._name)
timer = machine.Timer(HwPin._TimerMap[self._name][0], mode=machine.Timer.PWM)
self._pwm = timer.channel(HwPin._TimerMap[self._name][1], freq=20000, duty_cycle=(duty_cycle * 100))
def digital_read(self):
if self._function != 'dig':
self._function = 'dig'
self._config()
return self._pin()
def digital_write(self, value):
self._config()
self._pin(value)
def analog_read(self):
if self._function != 'ana':
self._function = 'ana'
self._config()
return self._apin()
def analog_write(self, value):
if self._function != 'pwm':
self._function = 'pwm'
self._config(value * 100)
self._pwm.duty_cycle(value * 100)
class VrPin:
def __init__(self, read=None, write=None):
self.read = read
self.write = write
class Terminal:
def __init__(self, blynk, pin):
self._blynk = blynk
self._pin = pin
def write(self, data):
self._blynk.virtual_write(self._pin, data)
def read(self, size):
return ''
def virtual_read(self):
pass
def virtual_write(self, value):
out = eval(value)
if out != None:
print(repr(out))
except:
exec(value)
except Exception as e:
print('Exception:\n ' + repr(e))
class Blynk:
def __init__(self, token, server='blynk-cloud.com', port=None, connect=True, wdt=True, ssl=False):
self._wdt = None
self._vr_pins = {}
self._do_connect = False
self._on_connect = None
self._task = None
self._task_period = 0
self._token = token
if isinstance (self._token, str):
self._token = bytes(token, 'ascii')
self._server = server
if port is None:
if ssl:
port = 8441
port = 8442
self._port = port
self._do_connect = connect
self._wdt = wdt
self._ssl = ssl
self.state = DISCONNECTED
def _format_msg(self, msg_type, *args):
data = bytes('\0'.join(map(str, args)), 'ascii')
return struct.pack(HDR_FMT, msg_type, self._new_msg_id(), len(data)) + data
def _handle_hw(self, data):
params = list(map(lambda x: x.decode('ascii'), data.split(b'\0')))
cmd = params.pop(0)
if cmd == 'info':
pass
elif cmd == 'pm':
pairs = zip(params[0::2], params[1::2])
for (pin, mode) in pairs:
pin = int(pin)
if mode != 'in' and mode != 'out' and mode != 'pu' and mode != 'pd':
raise ValueError("Unknown pin %d mode: %s" % (pin, mode))
self._hw_pins[pin] = HwPin(pin, mode, mode)
self._pins_configured = True
elif cmd == 'vw':
pin = int(params.pop(0))
if pin in self._vr_pins and self._vr_pins[pin].write:
for param in params:
self._vr_pins[pin].write(param)
print("Warning: Virtual write to unregistered pin %d" % pin)
elif cmd == 'vr':
if pin in self._vr_pins and self._vr_pins[pin].read:
self._vr_pins[pin].read()
print("Warning: Virtual read from unregistered pin %d" % pin)
elif self._pins_configured:
if cmd == 'dw':
val = int(params.pop(0))
self._hw_pins[pin].digital_write(val)
elif cmd == 'aw':
self._hw_pins[pin].analog_write(val)
elif cmd == 'dr':
val = self._hw_pins[pin].digital_read()
self._send(self._format_msg(MSG_HW, 'dw', pin, val))
elif cmd == 'ar':
val = self._hw_pins[pin].analog_read()
self._send(self._format_msg(MSG_HW, 'aw', pin, val))
raise ValueError("Unknown message cmd: %s" % cmd)
def _new_msg_id(self):
self._msg_id += 1
if (self._msg_id > 0xFFFF):
self._msg_id = 1
return self._msg_id
def _settimeout(self, timeout):
if timeout != self._timeout:
self._timeout = timeout
self.conn.settimeout(timeout)
def _recv(self, length, timeout=0):
self._settimeout (timeout)
self._rx_data += self.conn.recv(length)
except socket.timeout:
return b''
except socket.error as e:
if e.args[0] == EAGAIN:
return b''
raise
if len(self._rx_data) >= length:
data = self._rx_data[:length]
self._rx_data = self._rx_data[length:]
return data
return b''
def _send(self, data, send_anyway=False):
if self._tx_count < MAX_MSG_PER_SEC or send_anyway:
retries = 0
while retries <= MAX_TX_RETRIES:
self.conn.send(data)
self._tx_count += 1
break
except socket.error as er:
if er.args[0] != EAGAIN:
raise
time.sleep_ms(RE_TX_DELAY)
retries += 1
def _close(self, emsg=None):
self.conn.close()
time.sleep(RECONNECT_DELAY)
if emsg:
print('Error: %s, connection closed' % emsg)
def _server_alive(self):
c_time = int(time.time())
if self._m_time != c_time:
self._m_time = c_time
self._tx_count = 0
if self._wdt:
self._wdt.feed()
if self._last_hb_id != 0 and c_time - self._hb_time >= MAX_SOCK_TO:
return False
if c_time - self._hb_time >= HB_PERIOD and self.state == AUTHENTICATED:
self._hb_time = c_time
self._last_hb_id = self._new_msg_id()
self._send(struct.pack(HDR_FMT, MSG_PING, self._last_hb_id, 0), True)
return True
def _run_task(self):
if self._task:
c_millis = time.ticks_ms()
if c_millis - self._task_millis >= self._task_period:
self._task_millis += self._task_period
self._task()
def repl(self, pin):
repl = Terminal(self, pin)
self.add_virtual_pin(pin, repl.virtual_read, repl.virtual_write)
return repl
def notify(self, msg):
if self.state == AUTHENTICATED:
self._send(self._format_msg(MSG_NOTIFY, msg))
def tweet(self, msg):
self._send(self._format_msg(MSG_TWEET, msg))
def email(self, to, subject, body):
self._send(self._format_msg(MSG_EMAIL, to, subject, body))
def virtual_write(self, pin, val):
self._send(self._format_msg(MSG_HW, 'vw', pin, val))
def sync_all(self):
self._send(self._format_msg(MSG_HW_SYNC))
def sync_virtual(self, pin):
self._send(self._format_msg(MSG_HW_SYNC, 'vr', pin))
def add_virtual_pin(self, pin, read=None, write=None):
if isinstance(pin, int) and pin in range(0, MAX_VIRTUAL_PINS):
self._vr_pins[pin] = VrPin(read, write)
raise ValueError('the pin must be an integer between 0 and %d' % (MAX_VIRTUAL_PINS - 1))
def on_connect(self, func):
self._on_connect = func
def set_user_task(self, task, ms_period):
if ms_period % TASK_PERIOD_RES != 0:
raise ValueError('the user task period must be a multiple of %d ms' % TASK_PERIOD_RES)
self._task = task
self._task_period = ms_period
def connect(self):
self._do_connect = True
def disconnect(self):
def run(self):
self._start_time = time.ticks_ms()
self._task_millis = self._start_time
self._hw_pins = {}
self._rx_data = b''
self._msg_id = 1
self._pins_configured = False
self._timeout = None
self._tx_count = 0
self._m_time = 0
if self._wdt:
self._wdt = machine.WDT(timeout=WDT_TO)
while self.state != AUTHENTICATED:
self._run_task()
if self._wdt:
self._wdt.feed()
if self._do_connect:
self.state = CONNECTING
if self._ssl:
import ssl
print('SSL: Connecting to %s:%d' % (self._server, self._port))
ss = socket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_SEC)
self.conn = ssl.wrap_socket(ss, cert_reqs=ssl.CERT_REQUIRED, ca_certs='/flash/cert/ca.pem')
print('TCP: Connecting to %s:%d' % (self._server, self._port))
self.conn = socket.socket()
self.conn.connect(socket.getaddrinfo(self._server, self._port)[0][4])
except:
self._close('connection with the Blynk servers failed')
continue
self.state = AUTHENTICATING
hdr = struct.pack(HDR_FMT, MSG_LOGIN, self._new_msg_id(), len(self._token))
print('Blynk connection successful, authenticating...')
self._send(hdr + self._token, True)
data = self._recv(HDR_LEN, timeout=MAX_SOCK_TO)
if not data:
self._close('Blynk authentication timed out')
continue
msg_type, msg_id, status = struct.unpack(HDR_FMT, data)
if status != STA_SUCCESS or msg_id == 0:
self._close('Blynk authentication failed')
continue
self.state = AUTHENTICATED
self._send(self._format_msg(MSG_HW_INFO, "h-beat", HB_PERIOD, 'dev', 'WiPy', "cpu", "CC3200"))
print('Access granted, happy Blynking!')
if self._on_connect:
self._on_connect()
self._start_time = sleep_from_until(self._start_time, TASK_PERIOD_RES)
self._hb_time = 0
self._last_hb_id = 0
self._tx_count = 0
while self._do_connect:
data = self._recv(HDR_LEN, NON_BLK_SOCK)
if data:
msg_type, msg_id, msg_len = struct.unpack(HDR_FMT, data)
if msg_id == 0:
self._close('invalid msg id %d' % msg_id)
break
if msg_type == MSG_RSP:
if msg_id == self._last_hb_id:
elif msg_type == MSG_PING:
self._send(struct.pack(HDR_FMT, MSG_RSP, msg_id, STA_SUCCESS), True)
elif msg_type == MSG_HW or msg_type == MSG_BRIDGE:
data = self._recv(msg_len, MIN_SOCK_TO)
if data:
self._handle_hw(data)
self._close('unknown message type %d' % msg_type)
break
self._start_time = sleep_from_until(self._start_time, IDLE_TIME_MS)
if not self._server_alive():
self._close('Blynk server is offline')
break
self._run_task()
if not self._do_connect:
self._close()
print('Blynk disconnection requested by the user')
Wipy 2.0 & Blynk
Re: Wipy 2.0 & Blynk
The place to go for WiPy 2.0 support is the Pycom forum https://forum.pycom.io/.
