I currently have the micro-SD on the SF6W exposed in Windows File Explorer by calling the following line in boot.py:
pyb.usb_mode('VCP+MSC',msc=(pyb.Flash(), pyb.SDCard()))
However, when I make a modification to one or more of the contents of the SD card, it is not immediately reflected in File Explorer. I can view the changes in the REPL prompt. The only way I can view these changes in File Explorer is by unplugging the Pyboard from the PC and then plugging it back in.
Is there an alternative solution than this method? I ask because the act of unplugging/replugging the Pyboard requires opening up a new REPL prompt each time.
