I'm wondering if the littlefs block size can be configured in micropython. I am using logfiles to write to.
The command: 'info = os.statvfs("/data")' returns "File system block size: 4096, free blocks: 345"
Does this mean that every created file on the littlefs filesystem is by default 4096 bytes in size? Is it possible to reduce this size?
littlefs block size configurable?
Re: littlefs block size configurable?
block_size is that of the underlying flash chip, e.g. for erase. It does not affect the number and sizes of file. lfs can have more files than blocks.
It was my understanding that with a blocksize of 4096 it does not matter if the filesize is 1 byte or 4000 bytes. The file will be 4096 bytes in size...or isn't this correct?
Don’t think so. I just made a little test for confirmation. On a lfs file system with 255 blocks of 4096 byte size I have created 500 files of 256 byte size with different content. I could read them back properly with the right content, and delete them.
Yeah the block size for littlefs is just so that it manages the underlying flash device correctly.
Unlike fatfs where a single file must own the entire cluster.
