led flash 10 times, not 5?
Rissy
Post by Rissy » Sat Aug 27, 2022 1:09 pm
Why does this script flash the onboard LED on the Pico W, 10 times, instead of 5!?
import utime
led = machine.Pin("LED", machine.Pin.OUT)
count = 0
led.off()
while count < 5:
    led.toggle()
    utime.sleep(0.1)
    led.toggle()
    count = count + 1
    utime.sleep(0.5)
Rissy
Re: led flash 10 times, not 5?
Post by Rissy » Sat Aug 27, 2022 2:24 pm
This is my boot.py for the Pico W.
When i run it through Thonny, the LED flashes 10 times.
When i run it outside of Thonny, on boot up, the LED flashes 5 times as programmed.
Has anyone else had something similar this this type of oddity?
beetle
Post by beetle » Sat Aug 27, 2022 3:23 pm
Rissy, the code you show flashes the Led 5 times. exactly 5 times. As it happens I was putting the latest micropython on to a new rpi PicoW (V1.19.1) so just incase a bug had crept in as theres no stable release showing as yet I put your code on the board and ran it. 5 nice green flashes. :)
Edit: I see you have been putting in more info since I posted this about the code being in a boot.py. I tried to rename my flashing.py to boot.py but got some errors from Thonny. Possibly something to do with Thonny only having a Pico interpreter setting and not a PicoW interpreter. ??
Online
Post by Roberthh » Sat Aug 27, 2022 3:43 pm
Looks like a Thonny thing, executing boot.py twice, once in raw mode for the board set-up magic it does and once for the regular boot.
So a good rule, if something strange happens is go back to barre bone and kick out any "helpful" tools.
Rissy
Post by Rissy » Sat Aug 27, 2022 3:53 pm
Does that mean the Pico doesn't have a boot.py privilege then?
Rissy
Post by Rissy » Sat Aug 27, 2022 3:54 pm
Weird one for people to note, that one is!
Post by jimmo » Fri Sep 02, 2022 11:38 am
Remember that boot.py should only be used to configure hardware that needs to happen before main.py runs (or is required to load main.py, for example configuring filesystems). On the pyboard for example, you must configure the USB mode in boot.py if you want to see the output of main.py on the USB serial.
There are very few reasons to use boot.py on the Pico.
Post by dhylands » Tue Sep 06, 2022 5:30 pm
boot.py will run every time that the micropython board is soft reset, which included entering the RAW REPL. Programs like Thonny, rshell, mpremote all use the raw repl for every command that they execute.
rshell executes about 5 commands when it connects to a board, so your boot.py will get run 5 times. However, main.py doesn't get run when entering the RAW repl, just boot.py.
