[stackctrl.c line 59] nlr_raise(mp_obj_new_exception_msg(&mp_type_RuntimeError, "maximum recursion depth exceeded"));
I go to the definition (line 81 of nlr.h):
// use nlr_raise instead of nlr_jump so that debugging is easier
#ifndef DEBUG
#define nlr_raise(val) nlr_jump(val)
#else
#warning "this path gets hit"
#define nlr_raise(val) \
do { \
void *_val = val; \
assert(_val != NULL); \
assert(mp_obj_is_exception_instance(_val)); \
nlr_jump(_val); \
} while (0)
#endif
So this means nlr_jump is NULL?
Looking further up nlr.h, I comment out a few lines to get µPy to use the compiler's setjmp/longjmp:
#include <limits.h>
#include <setjmp.h>
#include <assert.h>
typedef struct _nlr_buf_t nlr_buf_t;
struct _nlr_buf_t {
// the entries here must all be machine word size
nlr_buf_t *prev;
void *ret_val;
// π
//#if !MICROPY_NLR_SETJMP
//#if defined(__i386__)
// void *regs[6];
//#elif defined(__x86_64__)
// #if defined(__CYGWIN__)
// void *regs[12];
// #else
// void *regs[8];
// #endif
//#elif defined(__thumb2__) || defined(__thumb__) || defined(__arm__)
// void *regs[10];
//#else
#define MICROPY_NLR_SETJMP (1)
// #warning "No native NLR support for this arch, using setjmp implementation"
//#endif
//#endif
#if MICROPY_NLR_SETJMP
jmp_buf jmpbuf;
#endif
extern nlr_buf_t *nlr_setjmp_top;
NORETURN void nlr_setjmp_jump(void *val);
// nlr_push() must be defined as a macro, because "The stack context will be
// invalidated if the function which called setjmp() returns."
#define nlr_push(buf) ((buf)->prev = nlr_setjmp_top, nlr_setjmp_top = (buf), setjmp((buf)->jmpbuf))
#define nlr_pop() { nlr_setjmp_top = nlr_setjmp_top->prev; }
#define nlr_jump(val) nlr_setjmp_jump(val)
#else
unsigned int nlr_push(nlr_buf_t *);
void nlr_pop(void);
NORETURN void nlr_jump(void *val);
#endif
// This must be implemented by a port. It's called by nlr_jump
// if no nlr buf has been pushed. It must not return, but rather
// should bail out with a fatal error.
void nlr_jump_fail(void *val);
#include <setjmp.h>
#include <stdio.h>
#include "mpconfig.h"
#include "nlr.h"
void nlr_setjmp_jump(void *val) {
nlr_buf_t *buf = nlr_setjmp_top;
nlr_setjmp_top = buf->prev;
buf->ret_val = val;
longjmp(buf->jmpbuf, 1);
#endif
What is going on here?
