Self balancing robot
stmfresser
Re: Self balancing robot
Postby stmfresser » Tue Nov 15, 2016 1:44 pm
i've built my self balancing robot and trying to port the c code into micropython. Unfortunately micropython is too slow on STM32F407 Board.
Is there any better µcontroller which is for micropython optimized.
https://www.youtube.com/watch?v=jPH4uLOQLpM
deshipu
Postby deshipu » Tue Nov 15, 2016 2:00 pm
Can you tell us what exactly is too slow? I'm sure the code can be improved to run faster in the critical places.
Postby pythoncoder » Tue Nov 15, 2016 2:26 pm
Indeed. I'm not alone in having used MicroPython for this purpose without needing any serious optimisation. Someone - I forget who - has flown a quadcopter which is a considerably more demanding proposition.
Are you sure speed is the problem? I experienced major difficulties which turned out to be entirely mechanical in origin. Vibration affecting the sensors.
stmfresser
Postby stmfresser » Tue Nov 15, 2016 4:42 pm
my python control loop code runs 30ms, it's getting slower with the time, my C control loop runs 10ms. The balance control loop needs max. 10ms.
Postby pythoncoder » Tue Nov 15, 2016 5:54 pm
In which case there is room for improvement. My control loop has an explicit delay to set the loop time to 5ms. Have you read the tutorial on improving MicroPython speed? See the list of tutorials herehttp://docs.micropython.org/en/latest/pyboard/reference/index.html.
Return to “Hardware Projects”
Who is online
Users browsing this forum: No registered users and 2 guests
