I try to get working the accelerometer W61P with micropython.
The documentation of all the i2c adresses are described here : https://drive.google.com/file/d/1d0UI3R ... sp=sharing
My verry simple code is here :
import utime
# construct spi
bus=I2C(scl=machine.Pin('Y9'), sda=machine.Pin('Y10'),freq=400000)
# send 0x2000 to soft reset sensor and wait 3 sec
re = bytearray([0x1a,0x40,0x00])
bus.writeto(0x50,re)
re2 = bytearray([0x00,0,0x00])
#bus.writeto(0x50,re2)
utime.sleep(1)
#scan for the sensor address
print(bus.scan())
while True :
#Initialize Sensor send 0x1000 to sensor to start continuous measurement
buf_angle = bus.readfrom_mem(0x50,0x3d,6)
X_Angle = ((buf_angle[1]<<8)|buf_angle[0])/32768*180
Y_Angle = ((buf_angle[3]<<8)|buf_angle[2])/32768*180
Z_Angle = ((buf_angle[5]<<8)|buf_angle[4])/32768*180
print('X_Angle',X_Angle,'Y_Angle',Y_Angle,'Z_Angle',Z_Angle)
buf_angular_velocity = bus.readfrom_mem(0x50,0x37,6)
X_AngVelocity = ((buf_angular_velocity[1]<<8)|buf_angular_velocity[0])/32768*2000
Y_AngVelocity = ((buf_angular_velocity[3]<<8)|buf_angular_velocity[2])/32768*2000
Z_AngVelocity = ((buf_angular_velocity[5]<<8)|buf_angular_velocity[4])/32768*2000
print('X_AngVelocity',X_AngVelocity,'Y_AngVelocity',Y_AngVelocity,'Z_AngVelocity',Z_AngVelocity)
buf_acceleration = bus.readfrom_mem(0x50,0x34,8)
print(buf_acceleration)
X_Acc = ((buf_acceleration[1]<<8)|buf_acceleration[0])/32768*16
Y_Acc = ((buf_acceleration[3]<<8)|buf_acceleration[2])/32768*16
Z_Acc = ((buf_acceleration[5]<<8)|buf_acceleration[4])/32768*16
Temp = ((buf_acceleration[7]<<8)|buf_acceleration[6])/32768*16
print('X_Acc',X_Acc,'Y_Acc',Y_Acc,'Z_Acc',Z_Acc)
print('temp',Temp)
break
I get some problems.
1) I can't manage to change the i2c adress of this chip.
I tried to do that according to the sec 5.2.28 of the documentation (link above)
utime.sleep(1)
Second problem, I get some weird values for the acceleration :
print('temp',Temp)
I'am sure is just a little small things, but I did not find my way alone, so thanks by advance if you find something that could help !
