Does anyone know the intimate specifications for a JST socket that'll fit a PyBoard 1.1?
It's obviously a 2 way, right-angle socket but there are so many multiple JST sub-variants (XH, PH, PHR, etc) that my brain starts spinning. I'd rather avoid ordering unwanted mis-sized components, so any pointers would be appreciated.
Specs for JST connector on PyBoard 1.1
Re: Specs for JST connector on PyBoard 1.1
Anything with a 2.0mm spacing of the pins will fit. It depends on the connector that your particular battery has as to which is the one you need.
I use something like this: http://www.digikey.com/product-detail/e ... -ND/926626
Thank you for pointers, Damien!
I'll get my calipers out and do some detailed datasheet dimension comparisons.
