I try to save value every 50ms. But when I make a delay each time I take value, I don't have a true 50ms between each value but more 49.619ms ; 49.67ms ; 49.792ms ....
So when I check the pyb.delay time to operation I have the same precision with this code :
from pyb import Pin, Timer
micros = pyb.Timer(8, prescaler=167, period=0x3fffffff)
print("start")
micros.counter(0)
start_micros = micros.counter()
pyb.delay(50)
pyb.delay(50-micros.counter)
end_micros = micros.counter()
print (micros.counter()/1000)
print("end")
I would like to know if it is possible to have a 50.000ms between each delay.
Make real 50.000ms delay
Re: Make real 50.000ms delay
That's extremely doubtful, even in C.
The issue is that there are interrupts running in the background, and these will always cause some variation somewhere.
You can setup a hardware timer to fire exactly every 50,000 msec, but there is no guarantee that your callback will execute exactly the same amount of time after the interrupt occurs. Your callback will fire with an average of 50,0000 msec, but not exactly.
To get repetitive exact times typically requires hardware, or very well constrained software (and python isn't going to give that to you).
The normal way to do this is in two stages. Use a hardware timer to trigger a reading interrupt handler. Read the value in the interrupt handler and save it to a circular buffer, doing the least amount of of work. This can now be read outside of the interrupt. If your interrupt priority is set up correctly, your interrupt handler will not be interrupted until you reset the mask. I have gotten uS precision on 12MHz CPUs doing this. It is mainly a problem of reading the data sheets as the actual code is generally very small because it has to be.
@mianos This is fine so long as you can guarantee that a higher priority interrupt won't be running at the time yours occurs.
